sparc
Veteran Member
- Joined
- Oct 2, 2011
- Messages
- 1,079
- Location
- NJ
- Tractor
- JD 4410, NH TC-25, Bobcat M610, JD X534, Dig-It Model 158, JD Ztrak 737. 6X4 Gator
So say magically your current pickup increased its' capacity 700 pounds. Would you do anything differently all the sudden?
What % of the time do you have you pickup maxed out on capacity where you would actually need the extra 700 pounds? For most people it's likely less than 1% of the time.
I'm not saying it's a bad thing but depending on how much it costs it might not be financially necessary to spend extra money to gain capacity that for most people is rarely if ever used. If there was no cost difference then its' a no brainer. But Aluminum is much more expensive than steel and will likely cost quite a bit more to make. We could make trucks out of carbon fiber and cut even more weight but at what point does the cost outweigh the benefit. That's all I'm saying.
Evry time that reduced weighttruck movesit will save fuel, regardless of any load onnthe bed or if a trailer is attached. Since as you point out most pickups spend most of their time empty the fuel savings seems to be more important than a couple hundred pounds gained in payload capacity.
