Opening Pop-Up is Not Believable
   / Opening Pop-Up is Not Believable #31
So you're saying it shows every time a page loads?
Yes, each time a new page loads, the pop up reappears.
For example if I click on news/feedback, the pop up will appear.
Then if I click on this thread, the popup will appear again.
Then if I click on page two, The pop up will pop up again.
Then if I click on page three, you guessed it, I get to cancel the pop up yet once again.
   / Opening Pop-Up is Not Believable #32
That's not the way it's suppose to work at all. It's suppose to show once every three days only. I tested it several times to see if I could get it to load on every page load and was unable to get it to load more than once per session.
Which browser and version are you using?
   / Opening Pop-Up is Not Believable #33
I mostly view TBN on my iPad or iPhone. The app is waaaaay better than the web site. Just my $.02
   / Opening Pop-Up is Not Believable #34
DIRTROAD said:
Sorry, but I can't use firefox because it is incompatible with my schools blackboard learning system.
Uh, can't you use multiple browsers? One for your learning system and another for some other purposes.
   / Opening Pop-Up is Not Believable #35
I use the latest version of Internet Explorer on a brand new (less than 2 months old) Dell Laptop.
Did you change something, because I haven't seen any pop-ups yet this morning?
Thank you, if you made changes.
   / Opening Pop-Up is Not Believable #36
I don't get the pop up on each page anymore; however, if I navigate away from TBN and come right back, I will get the pop up. Apparently, the three day rule doesn't apply to my computer. It is a thousand times better than it was before though. I can assure you that cookies are enabled also.
   / Opening Pop-Up is Not Believable #37
do you have medium high or higher security settings?
   / Opening Pop-Up is Not Believable #38
Today, for the first time, that annoying popup has appeared while using Firefox with AdBlock and NoScript. That won't do. Time to get aggressive and kill it once and for all. :mad:
   / Opening Pop-Up is Not Believable #39
The only solution that I have found is to remain logged in. Even then it still appears occasionally. Very aggrevating!
   / Opening Pop-Up is Not Believable #40
i never log out.. see no reason too!
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A52705)
2019 CATERPILLAR...
2021 CAN-AM OUTLANDER 650 XMR 4-WHEELER (A51406)
2021 CAN-AM...
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A53473)
2016 Ford F550 4x4...
2023 WESSEX RMX500 LOT NUMBER 44 (A53084)
2023 WESSEX RMX500...
2018 CATERPILLAR 950GC LOADER (A51246)
2018 CATERPILLAR...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A51691)
Generac Yanmar...
