Pallet fork suggestions
   / Pallet fork suggestions #11
Like these, grandpa has the construction forks on his too with the additional roll back built in and you can tilt them suckers waaay back.
United Heavy Duty Skid Steer Quick Attach Pallet Fork Attachment 42" Blades
These have some extra rollback built in:
   / Pallet fork suggestions #12
Titan is a good company, I got the 60 inch, use my for removing stumps and brush, they sent it with spear capability, but it interfere with my quick attach so I had to cut it off now works great.
the curl of my tractor is enough. I have scared my self couple of times.
   / Pallet fork suggestions #13
I just used my forks to lift a 4x5 round bale off a trailer and drove it to my feeder, I was surprised how well it handled a round bale from under, I guess I don't need a spear after all. I still didn't measure mine but they didn't cover the whole base of the round bale so I would guess 42" forks. I wouldn't have wanted any shorter, I had to have every inch under the bale with a good slant to keep it up there in travel. Worked out good though, accomplished my task.
   / Pallet fork suggestions #14
Bales can be moved with forks, that's for sure, but be careful. A spear pretty much prevents the bale from rolling back over the top of the implement and coming towards the operator. With forks, the only thing preventing this is the operator.
I'm not saying that it's gonna happen to you, but it's happened to many farmers. Here's one example:Kimberton Farmer Recounts Paralyzing Accident, Advocates for Farm Safety
There's a radio story about that farmer also. Point is, a spear is safer. If you use forks, be careful.
   / Pallet fork suggestions #15
I bought a set last January. Dealer stock had 4000# stamped on the side, adjustable, straight blade. Several weeks ago I used them to move 3ea. 24"x 20' corrugated horns (galvanized steel culverts) and place them side by side in a creek to make a crossing. Just drove up and put the forks under one, put my joystick in the lift direction, culvert rolled back to the backbrace and away I went. At the drop zone, I had driven stakes in the ground to limit the forward travel of the horns once I tilted the forks down and let them roll off. Worked just fine.
   / Pallet fork suggestions #16
I bought the 48" forks and from the operators seat I can just see the ends, if I would of bought the 42" forks I would not of been able to see the ends, I'm glad I did not get the roll back cage as it would of blocked my view. Before you purchase, cut two boards one 42" & 48" placed them at the front of the tractor and get in the operators seat and see if you can see the ends, if you can't see them picking up pallets will be hard.
   / Pallet fork suggestions #17
Wow,
That would be horrific and something to deff think about. These are the same forks I have but are not mine and my tractor is cabbed so there's a little protection there but I will most deff be careful.
   / Pallet fork suggestions #18
Wow,
Yep, bales, logs, whatever, you lift it up high, you'd better be paying attention. A false move with the joystick can send stuff heading back your way.
   / Pallet fork suggestions #19
Before you order make certain they are in stock. I ordered a pair of Clamp on forks with cross fork stabilizer on 11/25. I received the forks but not the stabilizer. I have been requesting an update to its status and finally got it today 12/21. The stabilizers are on back order and I won't get one until April. Seems odd as they are selling them online now and there is no indication they are on back-order.
If I was going to order from them again I would make certain they have them in stock.
   / Pallet fork suggestions #20
This fork at tomahawk attachment.com don't look bad for $407.00 says they are made in USA8e2f88745a665c0dcc0cbb5e9578d186_f26.jpg
UNUSED 20PCS Industrial Polyester Lifting Straps (A53117)
UNUSED 20PCS...
Goldoni 240 Tractor (RIDE AND DRIVE) (A50775)
Goldoni 240...
2018 Ford Fusion Hybrid Sedan (A55758)
2018 Ford Fusion...
40' High Cube Multi-Door Container (A53316)
40' High Cube...
2014 Ford Escape (A50323)
2014 Ford Escape...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A55301)
LIKE NEW 2023...
