photos of basement waterproofing with bx - questions and comments?
   / photos of basement waterproofing with bx - questions and comments? #41
IMO, this is a perfect DIY project....and this thread is perfect proof. You can work @ your own pace, and can spend that extra hour... or a day:D:D making sure your house is waterproof for years to come.. the $$ saved can go towards the top of the line waterproofing products...
Blueseal liquid rubber membrane
Delta plastic membrane
Socked 4" pipe, R20 EPS insulation, 6' geo fabric (wrapped under pipe and all the way up to grade backfilled with 4.5' of clear stone.
for the first time in 3 years there's not a single spider, potato bug, or any type of moisture loving creature in our basement this spring:D Not to mention the air quality is of living space quality:D
Quote on that Barkri12:D:D just kiddin'
   / photos of basement waterproofing with bx - questions and comments? #42
nice looking job.....
this is what i'd like to do when we build our new home.......thanks for posting..
the squidgee stuff i posted has a subfloor channel too......
usually the fixes for after the fact aren't as good as the ones installed during construction...
i'll tell ya, though, i'm impressed with mine......if i would have cut the floor and spent significant more money, i MAY have helped mine.....when i dug out for my sump pump it was all creek gravel....i live in a hollow that is a creek and the creek across the street rises, the ground is saturated to whatever height the creek is...
that why i bought my new property on top of a hill.....i'm the highest point on the whole entire hill.....:D
   / photos of basement waterproofing with bx - questions and comments? #43
Lots of good information in this thread and a job well done, too.
   / photos of basement waterproofing with bx - questions and comments? #44
In my previous life (20 years ago) I did waterproofing as a living. I am with JB here - interior drain tile /sump pump systems are generally the best way to go. They are virtually guaranteed to stop any water problem and are cheaper than digging up the outside perimeter. Doing the exterior perimeter can be 5-10 times more expensive than doing it from the inside, especially if there are obstacles. And interior systems can address issues where hydrostatic pressure, say from a high water table, directly beneath the slab, cause leakage at the cove joint
The OP did a very impressive job. The outside work will solve the problem in many cases - but without his own equipment and time, it could have been a very expensive job. With a hoe, it is great seat time! And more fun - interior work is labor intensive - hauling dirt/gravel/cement in 5 gallon buckets - no place to really use the tractor. But can be done as a DIY project.
Ironically, I was just at my DW's grandmother's house yesterday looking at putting in a system for her to save her some $$. 89 years old and lives by herself, on a fixed income, etc etc. Have to dust of some old knowledge
Another good thread on this subject was a job Scotty (Scott_Vt) did on his place. JB contributed a ton of good information in that thread
http://www.tractorbynet.com/forums/rural-living/72203-water-basement-help.html
   / photos of basement waterproofing with bx - questions and comments? #45
Choosing the right basement waterproofing company for your needs isn't as simple as leafing through the phone book. As with any major investment, there's a pretty substantial amount of research to do.
   / photos of basement waterproofing with bx - questions and comments? #46
Excellent thread! Here's a interesting situation that you people may have ran into...I need a little advice... The 12 year old house I bought about 2 years ago seems to have 2 separate perimeter drains. One on the outside, and one on the inside going to a sump pump. Here's the catch, My downspouts are connected to the drains, I put leaf guards on to protect the drains. I noticed the sump pump runs a little more than I'd like, and it failed after about a year of use last summer when we had a week of rain. The other day I was looking for the open air drain so I ran a garden hose to the west side downspout. Guess what? the water ran into my sump!!!:eek: I know the east side downspouts are not connected this way, and I think there may be a connection through the footing, I'm hoping there isn't a erosion issue under the footing leading to the inner drain!!!! I'm thinking of hiring a plumber with a camera scope to find the connection and then I'll dig it up and plug it. Is there any reason it should be this way???::mad: (I wonder if it could be a secondary way to protect the basement in case the pump fails???)
   / photos of basement waterproofing with bx - questions and comments? #47
If the pump fails it will be the primary source of your trouble :(
You probably wont find any one connection, just finding it's way under footing. An out side system should only be used with a gravity daylight exit drain. Never in combination with an inside system for just the exact reason you discovered. You should at least disconnect the roof leaders from that system, if you can't isolate the exterior system from the interior.
If there is no way to have a daylight exit drain then no system should be installed on the outside. An interior footing drain should always be installed regardless of if there will be one on the outside or not, easy to do for new construction, expensive to do on existing.
Just witnessed the same thing your describing at the house I worked on last Monday, I worked on the existing basement but they were putting an addition on the back of the house, the contractor put a sump pit in the inside with an interior perforated footing pipe (the white PVC type with holes just on the bottom, First mistake) then they put the same system on the outside.
This is a small lot with no way to have a gravity drain, they bedded the outside system in tons of crushed stone, I questioned the builder as to where the outside system would drain and the answer he got from the foundation guy was not clear at the time. When I came back last week they installed another sump pit on the outside, 7 ft deep!!! future nightmares. I don't care, more work for me in the future.
Ideally in that situation you damp proof the walls and back fill with just dirt compacting as you go, this way you hold as much water back as you can with compressed earth and monolithic concrete foundation, any water that does get by will be controlled by the interior system. with all that stone you are collecting ground water in a huge reservoir on the outside of the foundation. In this case they will have to run a pump in the outside pit or all that water will come through to the inside system, either way they will be pumping more water than is necessary.
This is an area of construction that is not well understood, there is alot of debate over the right way to do it, we often see builders sabotaging themselves with stubborn ways of thinking.
Again, more work for me so I've got no problem with it :)
JB.
   / photos of basement waterproofing with bx - questions and comments? #48
Never ever tie the gutter downs into the foundation drain tile.
4" perf PVC drain tile, with the holes DOWN and a filter sock is the best drain tile.
75% of basements that have a sump pump, could have easilly been built with a daylight, just lazy or "dumb" builders.
I gut out at least 1 basement a month (power off, vacant homes)that had water issuies, many are newer homes with walkout basements, that have sump pits/pumps ????
Day light if at ALL possible.
Nick
   / photos of basement waterproofing with bx - questions and comments? #49
Sorry if I missed it, but how do these inside systems address water entering walls from the outside? Seems like they're a much more convenient way to go about the problem, but are they as effective?
   / photos of basement waterproofing with bx - questions and comments? #50
I was going to get a laser level and get the elevations of all the parts concerned. I find it hard to believe that all that hose water could find it's way into the sump that quick without a direct connection. I will then cap it off if it is, and I wonder if I can drill a 1-1/2 hole in the footing without compromising it to drain the sump to open air??I'll leave the pump in just in case the drain fails... I'm going th re-route the gutters away on their own. Ant better suggestions are welcome.....Thanks for the input...
2006 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A59575)
2006 INTERNATIONAL...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2023 Kubota L6060HST Compact Utility Tractor (A56436)
2023 Kubota...
3Pt Aerway (A59814)
3Pt Aerway (A59814)
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
