Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #4,801
More snow I’m over winter o well let’s do this and my little helpers IMG_0803.JPGIMG_0804.JPGjob done IMG_0805.JPG
   / Pictures of your snow weapons #4,802
Very cute snow "weapons" you have there.. :thumbsup: :thumbsup:
   / Pictures of your snow weapons #4,804
Here is a pic of the snow we had overnight. Guess I will be blowing snow today in my heated cab.
   / Pictures of your snow weapons #4,806
Must be nice lol
Nicer than mine, haha! I was out last night after the snow tapered off a bit and turned to sleet. I just have to clean up the plow bank near my driveway and the slush that the state plow pushed back near the mailbox.
Wanted the bulk of it off the driveway, my wife leaves for work at 5:50am. Her Subaru gets through pretty much everything with snow tires, but I like it to be as easy as possible for her.
   / Pictures of your snow weapons #4,807
Is that a Massey workbull? Have one the grandfather in law said I can have going to try getting it running this spring. Too cold right now
   / Pictures of your snow weapons #4,808
Close enough, it’s a Massey 35 Utility. It’s identical to the Workbull, same chassis, hydraulics, everything. The only real difference is the Workbull has a large steel industrial looking grille surround built into the nose, and the hoods are different. Mine has the Ag style hood, but the rest is all industrial. (Heavy duty front axle, power steering, front mount hydraulic pump for the loader, etc...)
Mine is a 4cyl Continental, runs like a top. Below zero weather, it pops to life like it’s 85* and sunny. Too bad it leaks like a seive!
Hopefully yours has the Perkins, the diesels are awesome! That being said, I paid $1,000 for mine, not running, had been sitting under an overgrown carport for 10 years or so. 3pt hitch didn’t work- the lift cylinder had snapped off the lift cover! Replaced the hyd. lift cylinder, piston rings for lift cylinder too. I rebuilt the hydraulic pump (exploded control valve from water freezing in the bottom of the dump), new PTO seal, cleaned the sludge out of the trans and rear, had it running in about 25 minutes after getting it home.
Well worth the little money I’ve got into it. Less than $2k total investment for a 40hp machine with a loader.
   / Pictures of your snow weapons #4,809
:thumbsup::thumbsup:
I'm at the point that I don't even wear a coat when clearing snow. I thank my wife all the time for insisting I get a tractor with a cab. :D
   / Pictures of your snow weapons #4,810
This one is a 204 with reverse o matic but since it's mine for the taking and I think it will run with a little TLC I plan to give it a shot it is the gas engine (would be nice if it were diesel from what I've read about it) He also has a skid loader I may try to show some love to that as well. going to be busy with all this.
   / Pictures of your snow weapons #4,811
Very nice. They’re a powerful machine, if it’s got a loader with front mounted pump you have yourself a great machine. Put some weight in the back of it (filled tires, wheel weights, ballast box, etc...) and it’ll lift a good amount of weight. Post pics in the vintage Massey section when you get around to it!
   / Pictures of your snow weapons #4,812
Thanks I will post a revival thread once I get started on it if it ever warms up and stops snowing
   / Pictures of your snow weapons #4,814
had 18"+ new snowfall over past 24 hours. Caught a break today so i was able to clear off our place and 8 neighbors places in between working in town. Was 24 outside, but inside i had to turn down the heater...even though i was in shirtsleeves.shirt.jpg ac control.jpg
deep snow . the front blower worked great as always...snow 1.jpg snow 2.jpg snow 4.jpg snow 3.jpg
   / Pictures of your snow weapons #4,815
   / Pictures of your snow weapons #4,816
Had enough snow here that I had to decide which mound was the car and which was the tractor.
With drifting I had areas that had 3 feet of snow and average was close to 24 inches.
Where my drive meets the city road I had a real challenge as the city plow really filled in my entrance way.
My 'drift cutters' on the blower are 48 inches high and at times not enough.
Fortunately I have learned many techniques as basically I'm underpowered for my 60 inch blower but it was very time consuming.
Like blowing the top half on the first pass followed by the bottom remainder on second pass and next pass taking only 1/2 blower width etc.
Driving is getting hazardous what with all those high snow banks as you can't see cars emerging until its too late.
Worst yet is the guy that won't shovel and simply blast his way out.
By the same token the emerging driver is blind up to the point that he can see from his side window.
And some of you guys actually enjoy snow???
   / Pictures of your snow weapons #4,817
^ that exact reason is why my wife was hit by another driver a few years ago.
Some guy and his girlfriend tried to pull out of a side road onto the main road my wife was on. Luckily my wife was only doing 45mph, she swerved and avoided a direct hit/t-bone into his driver side door. Still ended up clipping his front left corner with her front right.
Both her airbags popped, gave her and her sister burns on their faces and chests. Took the whole front off her car, snapped lower control arm.
When police interviewed the guy, he said he couldn’t see so he just went for it.
   / Pictures of your snow weapons #4,818
We only got a inch or two but the wind was howling all night and by morning I had some 3-4 foot drifts. They were fun to clean up.:mad:
I have decided next year I'll have a blower for my tractor, I'm running out of room to push the snow. If I blow it away it'll be better. :thumbsup:
   / Pictures of your snow weapons #4,819
I got the chance to use a Kioti yesterday. The hydraulics were slow, and the drive by wire pedal system left a lot to be desired. It was nice to be in a cab, to bad the seat was uncomfortable. For me, I probably would not buy one. IMG_20190213_123404219.jpegIMG_20190213_123342972.jpegIMG_20190213_123357985.jpeg
   / Pictures of your snow weapons #4,820
skills4lou
Would higher RPM's make a differents?
2018 CATERPILLAR 313FL GC EXCAVATOR (A60429)
2018 CATERPILLAR...
20 UTILITY TRAILER (A55745)
20 UTILITY TRAILER...
1449 (A57192)
1449 (A57192)
UNUSED RAYTREE RMRB72-72" HYD POWER RAKE BUCKET (A60432)
UNUSED RAYTREE...
CAT 930M (A58214)
CAT 930M (A58214)
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
