Please Explain the use of a ToolBar/Drawbar
   / Please Explain the use of a ToolBar/Drawbar #41
It's been a while since we visited this one.. almost eight years for me.
Dan, if I were you I'd get a spare draw bar and weld a standard 2" receiver tube to it. Easy solution.
Problem is I'm looking to insert a hitch mounted sander spreader however the hitch isn't a standard size. Come to find out its a special size with unique receiver tube let alone hitch something...
   / Please Explain the use of a ToolBar/Drawbar #43
I used the draw bar to pull my Swisher rough cut mower. I have used the mower for years with my 4 wheeler but since I bought the tractor I wanted to use it instead. I plan on eventually getting a standard brush hog but the Swisher still works for now. The factory drawbar/tongue was just too low to keep the mower level, so I put the draw bar on the 3 pt hitch and can adjust the height as needed. I can also hook it on one side or the other to provide more offset from the tractor. This is on a new Mahindra Max 26XL.
   / Please Explain the use of a ToolBar/Drawbar #44
Can only remember using them as a kid on the old trailing implements. Had a 4 row ridger and seed drill behind one of those, and it was great for pulling things like a roller offset. Then you covered your tracks, if you went the right way round. Plus the 'topper' behind the old Fordson.. I use it as a pipe bender now, have two the same and put them together on the back links for bending steel. Have a series of steel pulleys and it works great
   / Please Explain the use of a ToolBar/Drawbar #45
Albeit late to the party, you all made some great contraptions. Does anyone know of a drawbar plate hitch that I could plug into the 2 & 1/2" by 1" or so inch receiver? This is so unlike my 2 inch truck receiver for towing that I don't have the slightest use for a draw bar with a ball on that. At the end of the day, I'm looking for a proper square hitch so I can mount a sander which is an alternative to the 3 point/pto driven sanders...
3 Point 2" Receiver Trailer Hitch Category 1 Tractor Tow Hitch Drawbar Adapter
or
King Kutter 3-pt. Trailer Mover with 2 - 5/16" Ball TM-GN by King Kutter Inc for $158.97 in King Kutter - Brands : Rural King
2013 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A54607)
2013 FREIGHTLINER...
2013 CATERPILLAR 320EL EXCAVATOR (A51246)
2013 CATERPILLAR...
Tires (A50322)
Tires (A50322)
2020 CHEVROLET SILVERADO (A53843)
2020 CHEVROLET...
ROBINSON CENTRIFUGE (A53843)
ROBINSON...
