Plowing?
/ Plowing? #1
swecksam
Elizabethton tn
new holland tz 24 da
I recently bought a NH TZ24DA and was wondering if it would pull a turning plow? I live in TN in an area properly named stoney creek and not sure if the hydro will pull one through rocky soil. Any suggestions?
/ Plowing? #2
Your specs show 24 HP @ the engine and 18 @ the PTO...
Your drawbar HP should be in the 14 HP range...
Your tractor is light and that will be the most hindrance...
I would think that a 10" or 12" small bottom plow is do-able...
/ Plowing?
I was thinking about a single 12. Do you think it would struggle with a tiller box? For what im doing I could use it the first year and then a turner would be easier after the first turning. This soil will be virgin.
/ Plowing?
How is the weather in the badger state? I think we have developed permafrost for the first time ever here.
/ Plowing? #6
Its hard to find used single bottom plows anywhere. Remember, you can always buy a two-bottom and take one off.
/ Plowing? #7
Your little ford is about the same size as my old JD 2305. They love to pull a 12 inch Brinly plow in the spring when the ground is soft. Later in the summer when the ground is dry and hard, the plow sometimes struggles because it doesn't have enough weight to sink deep into the ground.
/ Plowing? #8
I pulled a 2 bottom 12" plow with a Kubota B7800 in really rocky soil and heavy sod. It struggled with the first time around and then got better(easier). My 30 Hp compact tractor is 4wd, with loaded rear ag. tires. I also have a 22 Hp Kubota with a rear tiller. I quit using that as the rocky soil caused it to rattle my teeth. Tractor Supply carries a line of single bottom plows, as do others.(County Line, King Kutter, Howse, etc.). If there's a dealer in your area they may be able to tell you the capabilities of your machine. Good luck!
/ Plowing?
Thanks for the info guys. I feel more confident bout my little tractor now.
Electric Tricycle (A64194)
Electric Tricycle...
2007 International 4300 Cab & Chassis 438418 (A62613)
2007 International...
John Deere R15 Rotary Cutter (A64047)
John Deere R15...
2018 KEARNEY TRAILER 24 FT GOOSENECK TRI-AXLE (A63569)
2018 KEARNEY...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
2020 KENWORTH T680 6X4 T/A  SLEEPER  TRUCK TRACTOR (A59910)
2020 KENWORTH T680...
