Plumbing store vs Hydraulic store for adapter?
   / Plumbing store vs Hydraulic store for adapter? #11
In a 1/4 to 3/8 reducing bushing I don't believe its going to matter, brass or steel. Even in 1/4 to 1/2" or 1/4 to 3/4. Don't think I'd feel safe recommending 1/4 to 1" however.....
When making a decision on something like this, you have to look at the actual shape of the item and THEN decide about the amount of strength needed and available. In this case we are not talking about valves, fittings or sections of tube, but REDUCING BUSHINGS....
   / Plumbing store vs Hydraulic store for adapter? #12
have you ever seen a taper pipe reducing bushing set way proud of a fitting? i have.. that means you are now down to looking at wall strength for a portion of that fitting.
soundguy
   / Plumbing store vs Hydraulic store for adapter? #13
Soundguy makes a good point. Until a few years ago, most steel fittings were being manufactured with a yellow hexavalent (Chromium 6) plating that some people mistook for brass.
Due to environmental regulations, this plating is no longer being applied to fittings, but there are still a lot of fittings in the field (and in some inventories) that were made before the switch.
The new trivalent plating in use by most manufacturers is silver in appearance, and there should be a lot less confusion over what material you have.
   / Plumbing store vs Hydraulic store for adapter? #14
Just use a magnet and see if it will stick.
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
2 Electrical Boxes (A57454)
2 Electrical Boxes...
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
48x4 Mini Skid Trencher (A56436)
48x4 Mini Skid...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
