Pole bldg on grade
/ Pole bldg on grade #1
bones1
Platinum Member
St.Marys County. Maryland/Tall Timbers Md.
Farmtrac 300 dtc
Is it ok to bulid a pole building on a grade?It is about a 3 ft drop in the back over a 28 ft length.All of the pole barn builders,four so far, I have talked to insist on a nice level pad before they will build.I am sure it's been done and why couldn't I just close in the bottom later and back fill inside to grade? Wouldn't they just set longer poles in the back and level to the front.Am I missing something here,pls advise.
/ Pole bldg on grade #2
Not sure if you are missing anything other than the ease of getting a pad level without a building on it. Can't imagine any reason to put off doing the pad first as well as any reason the builders won't do your building with out a level pad unless it is a code requirement. Keep looking, you will eventually find someone that will do it your way even if it is against code.
I would do the pad first and would make sure that the pad was well above any possible invasion by water.
Farwell
/ Pole bldg on grade #3
I don't think the poles would take the pressure of the backfill. It could make the building lean to the back or even brake the poles. Larry
/ Pole bldg on grade #4
I was thinking something similar to Larry. Having three feet of exposed beam from the ground the the skirt has the potential to cause problems. PT wood likes to curl on it's own, and this might give it enough room to do so.
If I absolutely had to start construction before the pad was level, than I'd put larger poles in the ground. At least one size bigger than you need. I think you'll need the extra strength.
It sure seems like a much harder way to go about building a barn. Moving the dirt in later and compacting it is gonna be ten times the work and effort having to work around the walls. Compaction will be just about impossible when your trying to get it from both sides of the walls, which means it will continue to settle for years, even decades. No matter what, you'd never be able to pour a solid foundation tha wouldn't crack on you over time.
Anything's possible, but why do it the hard way?
Eddie
Never thought about the side pressure on the poles.I will re think this project.
I asked because I didn't want the pole guys to come out and say they can't set poles in 3-4 feet of fill.Is it ok to set poles in fill?This is the only spot left I have for a building and right now a 24x12 shed sits on it up on blocks.Anyway to move that shed with a tractor?Anyone done this.
Thanks for your replies so far.
/ Pole bldg on grade #6
Yes, you can set the poles in fill, but it needs to be compacted. When I worked in California, fill had to be compaceted to 98% (I think). Anyway, when it's compacted properly, fill material is just as solid, and sometimes, more solid than undesturbed soil.
Again, you soil and conditions will dictate what it takes to get compaction. Trying to build a lift that high with a compact tractor would be very dificult, but with the right equipment, it's not that big a deal at all.
Eddie
/ Pole bldg on grade #7
I`m haveing a pole barn built in November. I was told the poles are a set length/height. The builder told me if not a level pad I would lose ceiling height on short end of the barn. I guess they have a minimum depth to set the poles, other wise could do as you were speaking about and set the high end shallow. I`m looking at about a 1 to 1 1/2 foot difference in 30 feet
/ Pole bldg on grade #8
How much room do you have behind the downside of the intended building site and what type of soil conditions do you have?
I have about 30 ft behind proposed pad but the slope gets greater real quick back there.Soil is not clay, sandy though.
/ Pole bldg on grade #10
Maybe you should think of a retaining wall behind the shed to help support the pad.
Build the pad first or delay the posts.
Looks like a 4ft high retaining wall about 35 ft long along the back slope first. Then level pad to retaining wall compact gravel and set poles.
Thanks for all the ideas.
/ Pole bldg on grade #12
3 in 28 is quite a bit, but I have built pole barns on grades even greater than that. Your bidders are being lazy. They have to figure the extra cost of longer poles and more splashboard around the bottom.
In the 70's and 80's my dad and I built hundreds of pole barns all over the Ozarks (not a flat spot around for a hundred miles). For splashboard around the bottom we used penta treated 2 x 6 tongue and groove with the poles on 7-1/2 foot centers. I have seen many of those barns with 2 or 3 feet of fill inside the barn against the splashboard without any bulging on the outside. It would sure mean a lot less fill than leveling the pad completely first. I know you can't get penta anymore, but ICQ tongue and groove would work -- might have to track it down though.
This is exactly how I want it done.I have seen it done this way before but can't find a builder that will do it.The three I have called so far all need a level pad, no more than 6 '' out before they will build.What is ICQ tongue and grrove anyway?Longer poles and extra splashboard in the back can't be too hard.Or can it?
/ Pole bldg on grade #14
FWIW . .I just finished up a 30x40 Pole barn with about 3ft of drop from the from to back. (40 ft side). The key is to get your compacting done and do it well. The builder I used (Ragland) said that they want at least 1 foot in undisturbed soil but will build in fill if the buyer demands it. (they sink the posts 5 foot) I built up my pad in 8-10 inch depths driving over it repeatedly and makeing sure it good a good soaking between layers. So far so good. (knock on wood). 140 hours on the tractor this summer moving dirt . .sure wish I had a bigger bucket. :)
Have a good one,
Dave
/ Pole bldg on grade #15
bones1 said:
right now a 24x12 shed sits on it up on blocks.Anyway to move that shed with a tractor? Anyone done this.
I just moved a 12' x 16' buy jacking it up and placing it on crisco lubed PT Lanscape timbers. I had to go from one side to the other and walk it a foot or so at a time.
Pushed it a 100 ft with my 21hp Kioti. The fun part was turning it around !
Jim
/ Pole bldg on grade #16
Have a good one,
Dave
It still wouldn't be big enough.
They never are.
/ Pole bldg on grade #17
You could but that's sure doing it the hard way filled with regrets and frustration.
DON'T ask me how I know.
I learned a long time ago that you can't have the building site too prepared. That includes every thing from Mobile Homes To Pole buildings but I was to stupid to follow my own advice when I had my 2 pole buildings built which lead to a lot of grief and gripping getting the inside leveled and the proper grade and drainage on the out side. Had I heeded my on advice things would have probably been 3 times easier and I would have wound up with a much better job.
Been There Done that but didn't even get a T shirt. But I wound up with a lot of sweat so could have used a few sweat shirts.
MY First Car
http://chevy.tocmp.com/chevyscrapbook/files/kamp50.jpg
/ Pole bldg on grade #18
Since this thread has already been brought up again. I built a 30x48. I had about a 20" drop from back to front. I just dug holes and plopped the poles in the ground.:D Some folks told me I "did it wrong," but in the end my little NH didn't have any problems pulling the top soil out and putting "fill" back in. If I had done it "properly," I probably still wouldn't have my garage. As it is, my garage as been finished now for over a year, and I have no signs of problems nor regrets. The way I did it, it allowed me to keep my tractor out of the weather until I was truly finished.
Your mileage may vary, but this method worked just fine for me.
/ Pole bldg on grade #19
One of my pole buildings has a 3' drop in 76 feet.
That's a lot of slope so 3 feet in 28 foot is really steep.
Get the site properly to grade before you even think about starting the building and save your self a lot of problems.
I learned this in the school of hard knocks.
/ Pole bldg on grade #20
Farwell
Do it the easy way first or the hard way last!
Tandem Axle Rear Truck Frame (A59230)
Tandem Axle Rear...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
Dump Truck Body with Tarp System (A55851)
Dump Truck Body...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
2012 Ford F-350 4x4 Ext. Cab Pickup Truck (A59230)
2012 Ford F-350...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
