post hole digger
/ post hole digger #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
I live on the side of a mountain (hill). Needless to say it's quite rocky. I really have a big need for post holes. Is a 3pt. tractor post hole digger out of the question in my circumstance?
/ post hole digger #2
When you say rocky, do you mean large buried boulders, or simply lots of stone, baseball size or smaller? If you can safely operate the tractor on your hillsides, you can likely do the same with an auger. I have found that tree roots, 6" in dia. and BIG rocks cause trouble.
Good luck.
/ post hole digger #3
You might need to use a hydraulic "down" cylinder to apply downward pressure to help that auger bore holes for you. Or, get a hydraulic auger that attaches to your front end loader bucket and use those cylinders to apply down pressure. B.
/ post hole digger #4
Careful augers can drive themselves in like a wood screw, the only way to withdraw them is to unscrew them. In our area (canadian shield) rock can make augers almost useless. Our soil on average would be 40-60% rock and the balance being clay, the rocks range from the size of your fist to a small car. However it's the stuff the size of a basketball to a bathtub in a pile that an auger will screw itself into. The only way we have rescued a few augers is to put a 4' pipe wrench with a length of pipe and some strong backs. We have cut off a couple too. Have a good bar handy you may need to remove some by hand. Good luck, slow and steady will win the race.
/ post hole digger
My soil is mixed but some areas rock out crop. I do have shale and clay. I have lots of uses for an auger. Is the tractor auger supply any good?
/ post hole digger #6
I have dug a few holes with a Tractor Supply augur without breaking it. But it was only a few. If you do buy a PHD just remember , SAFETY first .
/ post hole digger #7
I forgot to add some info another set of posters once shared with us here on TbN: sharp cutters on your PHD make a ton of difference in how easily they cut holes. And, I have had to use my 30" pipe wrench with a cheater pipe to extract my auger- it ain't fun.
/ post hole digger #8
Thick tree roots can also sometimes snag an auger bit. I'm pretty happy with the effectiveness and versatility of my hydraulic auger (I like the ability to push down and reverse)...though I'm planning on installing a back-up or trailer hitch camera on the FEL arms so I can more accurately position the auger tip.
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
2016 Autocar Xpeditor T/A Side Loader Garbage Truck (A61573)
2016 Autocar...
2024 Load Trailer 20ft T/A Flatbed Equipment Trailer (A56859)
2024 Load Trailer...
2017 PETERBILT 579 DAY CAB (A63569)
2017 PETERBILT 579...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
Arrow Quip 10' Bow Gate (A64047)
Arrow Quip 10' Bow...
