Pre-heat for stick weld?
   / Pre-heat for stick weld? #31
i never preheat on mild steel.. but do on picky stuff like cast iron. have had great results with that. must have at least 4 CI welds here recently with no ill results..
one of em was a repair cleaning up someone else's hack welding job where they really mauled a loader bracket.. spider webbed it everywhere..
soundguy
   / Pre-heat for stick weld? #32
Certain machinery manufactures used steel of a higher carbon content, this could sometimes be prone to cracking, preheat may be advisable in this situation although I have seen a great amount of this steel welded with a
7014 rod, the only preheat would have been from the goughing/grinding in the joint preparation.
Welded worn slip down chisel plough points together to make one a great many times, the only preheat was from grinding the V joint (they were 1/2"
thick), used a 7016 rod.
Is there no practical way to determine the carbon amount? You know, other than asking old carbon-credit-Al to take a look at it?
   / Pre-heat for stick weld? #35
being a welder, I never preheat steel, unless it is cover with snow, ice, or rain, most important is that the area 2 b welded is clean, and your welding rods are not stored where they can get moisture in them, when stick welding aluminum I do pre heat with a torch 2 get moisture out.
   / Pre-heat for stick weld? #36
Yeah that pre-heating is a wife's tale. Nobody really does it! :laughing:
Dumb question; in the second (right hand) pic is he preheating because of the difference in steel thicknesses?
   / Pre-heat for stick weld? #37
For most of the stuff we do it's not necessary to preheat. I used to work in a power plant and sometimes doing repair on big drums and headers we required a significant amount of preheat followed up with UT and X-ray inspections.
   / Pre-heat for stick weld? #38
Jstpssng I really don't know the reason why he is pre-heating, I stole that picture off the AWS site. According to the thread he was getting ready to take a 6-G open root, test w/ restriction ring, with dual shield and SMAW. There could be a multitude of reasons for the pre-heat. I don't remember him mentioning why either, could be as simple as too take the chill off the pipe. Some guys like to pre-heat before a test, especially a bend test. Depending on the type of material the WPS may specify a certain degree of pre-heat. Like I said a multitude of reasons.
   / Pre-heat for stick weld? #39
Thanks, I was just curious.
2006 John Deere 4120 Tractor (A51573)
2006 John Deere...
2014 Chevrolet Impala Limited Sedan (A51694)
2014 Chevrolet...
1996 JLG Commander CM2033 20ft Electric Scissor Lift (A51691)
1996 JLG Commander...
JOHN DEERE 560M LOT NUMBER 28 (A53084)
JOHN DEERE 560M...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A53472)
2016 Kawasaki 70...
American Farmworks 15 Mile Fence Controller (A51573)
American Farmworks...
