pressure plate
/ pressure plate #1
kennyl123
Pollock, LA
Ford 2000
I have 1972 Ford 2000 3 cyl. diesel 6 speed trans. pto. is trans. drive. My new pressure plate has a flat piece of metal with a square slot cut in it under each of the three adjusting nuts of the fingers. They are painted yellow. The adjusting nuts sit on a raised square platform that is a good bit higher than the yellow spacers so they just fall out. I can slide them in and out with ease. I can't see any way to keep them in place. My old pressure plate does not have any spacers under the adj. nuts. Why are these even on there and what should I do with them?
Thanks Kenny
/ pressure plate #2
They are for shipping. They were used tight until you bolted the pressure plate down, then they get loose. Toss them.
/ pressure plate
Thanks man, I was hoping it was something like that.
2018 FREIGHTLINER CASCADIA CA125 DC 6X4 T/A DAY CAB TRUCK TRACTOR (A59912)
2018 FREIGHTLINER...
2015 Freightliner M2 106 Petersen TL3 Forestry Grapple Truck (A61573)
2015 Freightliner...
2016 Peterbilt 320 EZ Pack 40yd Front Loader Garbage Truck (A61573)
2016 Peterbilt 320...
REDDICK 300 GALLON SPRAYER (A63291)
REDDICK 300 GALLON...
LMC Nitrogen Applicator (A62177)
LMC Nitrogen...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
