Propane Gas Fireplace
   / Propane Gas Fireplace #11
CurlyDave said:
We are putting a propane built-in fireplace in the living room of our new house.
Our GC has suggested a supplier who only carries Lennox brand.
Does anyone have any experience with this brand? Any other brands we should consider?
Any brands to avoid?
Dave,
Are you talking about a vented or un-vented fire place with logs ? Out of All the brands that I have come in contact with ,I don't find any brand better than the other. H.D. sells them as well as other stores . Vanguard use to be a good brand I think they were bought out a while back. If you go with the un- vented fire box with un- vented logs be sure that your mantle (if wood )above the fire place in within the factory specs. or a heat deflector is required at the fire place opening. Alot of heat comes out of that opening when the logs are on. It will give you the specs in the installation papers with the logs
   / Propane Gas Fireplace #12
The dogs look like twins. Maybe a DNA check is in order...
   / Propane Gas Fireplace #13
I've had two Vermont Castings Gas fireplaces. One was natural gas the other propane. Both units worked great and had no problems with either one. I also had Lennox products and they were fantastic.
   / Propane Gas Fireplace #14
   / Propane Gas Fireplace #15
Jimbrown said:
. But agin a nice glass of wine in front of the fire place is worth the pennies. here is pic of mine
Wine? Now you have my attention, I just happen to have a few bottles around the house that my wife and enjoy around the fireplace also.
kenmac said:
Dave,
This would be a direct-vent fireplace (that is a type of vent which uses double-wall pipe to supply outside air for combustion), with a circulating fan for room heating. They actually look pretty efficient.
Looks like the Lennox brand is going to be OK, so we will probably go with that.
I don't have the paperwork here with me, but efficiency is in the 85% range.
   / Propane Gas Fireplace #17
I know what you are talking about on the direct vent. But, I'am just curious as to why you would go with 85% efficiency logs insteat of the 99.9% efficienty logs without a vent ?
   / Propane Gas Fireplace #18
Even though unvented gas heaters are legal in many states, it still doesn't seem like a great idea to me. Sure, in some ways it is no worse than having a gas cooktop running but you don't generally do that 24hrs a day with the house buttoned up tight. People notice odd films developing on their windows, there are at least trace amounts of air pollutants discharged into the living space too.
Here is an interesting summary of the "con" position from a Canadian website:
“For $500, you can have this unvented gas log that will throw off heat, water vapour (adding to the humidity levels in the home), traces of carbon monoxide, sulphur dioxide and nitrous oxides, and may, if not maintained, operated or installed correctly, kill you and your family in your sleep. Or, you can have this direct vent fireplace that uses outside air in a sealed combustion system, and only delivers heat into your home, allowing you and your family to sleep in safety for $2,200.”
I guess it’s all in how you ask the question.
Perhaps one of the better quotes I have read in this debate came from one of the many opponents to unvented, Jim Hermann of The Earth Stove, who said: “You don’t need a scientist, you need a psychiatrist.”
I'll accept the 15% penalty for peace of mind.
   / Propane Gas Fireplace #19
Afternoon Island Tractor,
I concur, my propane insert is vented and I feel alot better about going to sleep at night with a pretty good chance of waking up in the morning ;) I can live with the 85% efficiency !
On the other hand my friend had a Vermont Castings un-vented that he swears by :confused: Plus he gets the benefit of the water vapor also. Im happy with what I have and really wouldnt change ! :)
   / Propane Gas Fireplace #20
We've had unvented propane heat for 15 years or so. The first was a Renai infrared. That was in our previous house. This house has a fireplace so we installed an unvented gas log heater. It's the Vanguard's ChaRealistic. It's OK and looks like real logs burning but it doesn't put out the heat of the Renai.
EDIT-Pardon my spelling. Renai should have been Rinnai and should have been radiant instead of infrared.
John Deere 5520 4WD Tractor (A49251)
John Deere 5520...
2005 International Rollback Truck w/ Title (A49251)
2005 International...
Single Axle Trailer (NO Title) (A49251)
Single Axle...
2014 FREIGHTLINER M2 (A48992)
2014 FREIGHTLINER...
Single Axle Trailer (A49251)
Single Axle...
2018 FREIGHTLINER CORONADO SLEEPER TRUCK (A50046)
2018 FREIGHTLINER...
