pros and cons to running a 4WD tractor in 2WD
   / pros and cons to running a 4WD tractor in 2WD #21
</font><font color="blue" class="small">( For many operations like soil tillage, fuel consumption is significantly increased when operating in 2wd.
As fuel costs have risen, the popularity of 2wd has decreased, especially for ag operations. )</font>
I think I have to disagree with these 2. You will not burn more fuel running in 2wd when you have a 4wd. There is really no dead weight, the front axles are freewheeling. And I don't think fuel costs cause more 4wd to be sold. The main reason for the 4wd (IMO) is most here are dealing with small CUT tractors that are light. The 4wd gives them the abilit to do more work instead of slipping. Yes there are larger 100+hp tractors with 4wd now, this is because of the conditions they are working in, mud and such. A Combine with 4wd can work longer in a wet condition than a 2wd.
   / pros and cons to running a 4WD tractor in 2WD #22
What are you calling 4 wheel assist and how does it differ from 4WD? Is there a clutch in the transfer case that slips the front drive shaft so it only pulls a little bit as opposed to pulling full strength? Just curious.
   / pros and cons to running a 4WD tractor in 2WD #23
My L3130 is listed as front wheel assist instead of 4wd although I seem to say 4wd all the time. There is a lever that lets you run in 2wd or 4wd. What exactly makes the difference between front assist and 4wd is not clear to me either.
An earlier poster stated that front assist is a 2wd tractor with 4wd drive added on to it. I would tend to disagree with that since the Grand L series Kubotas for example was a new design.
...When putting it in 4wd it is direct drive between the front and rear, no clutch or fluid coupling to let it slip.
   / pros and cons to running a 4WD tractor in 2WD #24
I can't imagine any harm would come to the tractor as the result of using 2wd. However I always use 4wd unless on pavement, because my B2710 just does not get good traction turning on flat dry grass in 2wd. It is so light, it needs 4wd all the time.
   / pros and cons to running a 4WD tractor in 2WD #25
What we normally call 4wd here on TBN is actually front wheel assist. 4WD is technically a tractor that has four wheels of the same size and bends in the middle. If you look at the stats that are published by the manufactures they all list them this way. The small front wheels help out or assist the large rear wheels. That is why they call it front wheel assist. Here is one of the sites that list tractor sales as such. Front wheel assist tractors are included in the 2wd figures.
   / pros and cons to running a 4WD tractor in 2WD #26
In uneven terrain like we have here, I see no reason to ever go out of 4wd except for going a long distance on paved surface to save wear on the front tires, which rotate a tad faster than the fronts.
Doubt fuel consumption is affected as it is most affected by weight and load factors.
Ralph
   / pros and cons to running a 4WD tractor in 2WD #27
I used to have a '91 Kubota B2150. I forgot to take it out of FWD and went to a neighbor's place to pick up a plow. Went down the road in 3 high. The tractor never leaked a drop of anything until that! The oil in the front blew past the seal and made a mess. I now have a '04 MF 1433v and both manuals advise to use FWD only when needed.
   / pros and cons to running a 4WD tractor in 2WD #28
Agreed, braking is what makes me reach for 4WD assist faster than anything. Steep downhills in snow (asphalt too), trailering, or the need for improved forward bite are the only times I'm in 4WD. But that's my standard configuration with loaded rears and BH out back. Plenty of 2WD traction, even for the FEL in loose materials. However if your light in the back for any reason and seldom transition asphalt I think I'd be in 4WD a lot more. So the answer is configuration and usage based. Bet 80+% of us would be in the same drive configuration on the same tractor in the same situation. The posts don't necessarily reflect that continuity though.
   / pros and cons to running a 4WD tractor in 2WD #29
I typically leave my tractor in 4wd. My farm is uneven terrain and I find myself needing it more often than not when running a box blade/disk/tiller/and even a bush hog.
   / pros and cons to running a 4WD tractor in 2WD #30
Since adding the additional rear wheels the only time I've needed 4 wheel assist is when operating with heavy ground engagment attachments, like my pond scoop. Normally stepping on the differential lock is enough.
   / pros and cons to running a 4WD tractor in 2WD #31
I use 2WD when mowing and usually have to go 4WD with loader work and digging. Sometimes the diff lock is enough to get moving again but after doing that a few times I then go ahead and switch to 4WD. I don't even think about fuel consumption - unless I am running out
So you have quads on the rear of your tractor???
Bob
   / pros and cons to running a 4WD tractor in 2WD #33
Like it or not, getting stuck and excessive slippage are just not in my agenda anymore. That's why I keep the tractor in 4wd all the time. My property is hilly and rough terrain and I never go on pavement. I also engage the differential lock when straight line pulling before I need it for the same reason. Makes life so much easier when working. Occasionally I do forget to disengage the diff lock when using the turning brakes??:eek:
   / pros and cons to running a 4WD tractor in 2WD #34
Bob
Yes I manage to tip it over once. Gettin' off was near impossible, and the steerin' wheel got bent on my right leg. I'm of the opinion that the exhaust stack kept it from rolling over on me. I was backing up, not paying attention to the front end, and the downhill front wheel dropped into a hole. Doubling the rear wheels was the easiest solution. That little atvar picture will give you an idea of how it looks.
Wow, Quads look like they make the tractor near impossible to tip. When you have time, post a bigger pic.
Bob
   / pros and cons to running a 4WD tractor in 2WD #36
This is the biggest I have. But I have a bigger camera, give me a couple of days.
   / pros and cons to running a 4WD tractor in 2WD #37
My yard is quite uneven and hilly so I use 4WD almost all the time when mowing. Also, when pulling a trailer on my hilly property the 4WD greatly enhances the braking and overall traction. Every once in a while I'll forget to go back into 2WD when I go on the hard road, but rarely. It doesn't seem to tear up the yard anymore with the indy tires in 4 or 2 wheel drive. I feel the extra tractability more than offsets any premature wear concerns I might have. I just feel much more stable in 4Wd.
John
   / pros and cons to running a 4WD tractor in 2WD #38
I rarely use 4wd. I use it only when necessary. Mowing in 4wd makes the turning radius longer/wider and causes more damage to the turf when turning.
4wd comes in handy when doing FEL work.
Volfandt
   / pros and cons to running a 4WD tractor in 2WD #39
Doc,
I think you also have to consider the tractor itself, along with your terrain. I have a 1320 with turfs... I leave it in 4WD all the time, even mowing, unless on asphalt. I took an unplanned ride down a wet grassy hill just like another poster because I switched it out and forgot to put it back in 4WD. Not gonna make that mistake again. It's worked well so far with minimal tire wear.
I too have a TN and I rarely use 4WD, it's just not needed for most uses. Either way your not going to damage the tractor, that's why you have the lever.... to choose what works best for your situation.
Trail_Time said:
Doc,
Another TN70 owner!!!!!!!!!!!!!!! :D
Boy, do I have a lot of questions for you.
Bob
2014 International PayStar 5900i Flatbed Truck (A55973)
2014 International...
2022 FORD F-150 XLT CREW CAB TRUCK (A59823)
2022 FORD F-150...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2018 CATERPILLAR 305E2 CR EXCAVATOR (A60429)
2018 CATERPILLAR...
EXCAVATOR RIPPER (A58214)
EXCAVATOR RIPPER...
2020 CATERPILLAR 289D3 SKID STEER (A60429)
2020 CATERPILLAR...
