PTO Driven Water Pump
/ PTO Driven Water Pump #1
kday64
South Eastern Connecticut
Kubota BX2360
Hey all,
I was curious if anyone has any experience with Trunk Pumps.
I think $3K is a bit expensive, so does anyone know of any good alternatives?
I am not oppose to (re)learning how to weld and making one from scratch to save $$$. Best I can tell I would need the following:
- Self Priming Pump 2" suction (rated for 20HP)
- Reversing gear box (apperently water pumps spin counter clockwise)
- Much angle iron
- Cat. 1 3pt Blank
- Drive shaft
I am interested in the project because last spring my entire neighborhood flooded with the melting snow an one heavy rain. I am think I will be able to save myself and the neighbors some $$$. Two houses down had 5 feet of standing water for two weeks.
~Kevin
/ PTO Driven Water Pump #2
IMO...The trunk pumps are cool, but I think you would be better off getting a regular pump for $500 vs the $3k for a trunk pump...If you really wanted to move it with the tractor you could get a carryall for $120...:thumbsup:
/ PTO Driven Water Pump #4
For under $700 you could have a 3 inch trash pump that will move the same amount of water.
I have used 6 inch and 8 inch pto pumps they really move the water but for small stuff I use electic 2 inch or rent a 4 inch at RSC.
2017 Ford Fusion SE Sedan (A64557)
2017 Ford Fusion...
2021 CATERPILLAR 303.5CR EXCAVATOR (A65053)
2021 CATERPILLAR...
2025 LandHonor LHR-DFP10 Diesel Fuel Transfer Pump (A64194)
2025 LandHonor...
2437 (A65640)
2437 (A65640)
2021 Felling FT-45-2LP 29ft. 26 Ton Tag Trailer (A64194)
2021 Felling...
2016 Volvo XC60 SUV (A64557)
2016 Volvo XC60...
