PTO Thingamajig. Any body know what it is?
   / PTO Thingamajig. Any body know what it is? #12
I don't think it sips in the sense that you're thinking. I think that when the flywheel --let's say a baler--begins to "drive" the PTO on the tractor, this thing slips. In addition, when you turn the tractor PTO off, the things slips so the baler flywheel doesn't drive the tractor. I think that's what made the clicking sound when I shut off my baler and the flywheel kept turning but the tractor PTO did not. It just free-wheeled. I'm not positive but pretty sure I have this right
I agree, it is not a friction slip clutch like is found on bush hogs and tillers. I think it only slips in one direction and it will make a popping noise as the chipper winds down. I think if you take it apart you will find a spring loaded sloping ramp down to a 90 degree cog that engages positively in the power on position but allows the chipper to wind down while the tractor PTO is stopped turning. These things are common on the old square balers that have a big inertia flywheel.
   / PTO Thingamajig. Any body know what it is? #13
The OP's photo is an exact match for the M-Type friction clutch on this website. The manufacturer says about it:
" The friction clutch is the only torque limiter that has the
ability to continuously transmit power (at a reduced
level) while overloaded. This is valuable during start
up of high inertia machines, as well as for leveling out
torsional fluctuations due to high cyclic loads. The
TorQmaster patented technology dissipates heat
quickly, improving durability while protecting the
machine."
So it's for starting a heavy load, not as an over-riding clutch to keep the flywheel from driving the tractor through the PTO.
   / PTO Thingamajig. Any body know what it is? #14
Still don't know why it is causing his tractor to bog down. There has to be something else doing that.
   / PTO Thingamajig. Any body know what it is? #15
Its used as a type of torque dampener, it shouldnt cause the tractor to bog down, It is meant to keep from loadshocking the pto driveline.
   / PTO Thingamajig. Any body know what it is? #16
That's what I'm saying. The OP said it was bogging his 70 hp tractor down. It would have to be the implement doing that, not this device.
On a side note, I love the PTO on my little 45 hp tractor. Hydraulic clutch activation with a lever. Insulates against shock loads and operates independently of the drive gears and clutch.
   / PTO Thingamajig. Any body know what it is? #17
If the chipper and flywheel are big enough that would bog the tractor down. I would take the clutch apart and inspect it.
   / PTO Thingamajig. Any body know what it is? #18
its a friction clutch.....its used to replace shear pins..if the chipper drum becomes stuck it will not break the engine crank when it comes to a dead stop.
   / PTO Thingamajig. Any body know what it is? #19
I think spokane1 is right.
If you open the clutch up be careful as any springs will will escape FAST.
   / PTO Thingamajig. Any body know what it is? #20
I'm not sure why he needs to take it apart. There is no indication that it isn't functioning properly. As mentioned, if the tractor is bogging down it is the chipper/flywheel, not the slip clutch. The clutch has nothing to do with the load of running the implement, only shock loads. So unless the OP is worried that it isn't slipping then there is no need to take it apart.
2011 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2011 Ford F-150...
LOAD OUT INFORMATION (A53084)
LOAD OUT...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
New/Unused Mower King 48in Quick Attach Trencher (A51573)
New/Unused Mower...
2021 JOHN DEERE CP690 LOT NUMBER 196 (A53084)
2021 JOHN DEERE...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
