It's definitely a friction clutch and should be protecting both machines from one another. If set right it would overrun on a hard stop and slip on an obstacle/hard start. 1000# takes a lot to stop or start moving... that clutch (once you clean and adjust it) will slip at a torque range/load you decide. Supposedly JD protects theirs internally, but is a much more expensive and less accessible system--in the event it does not function as designed--the tractor gets taken apart.
There should be a number of discs and springs clamped by the bolts on the perimeter. Check for corrosion (clean) and glazing on brake/clutch material (removing to dull finish/replace if too far gone).
I would not run a machine with a dual-purpose clutch built in the driveline that has failed--enough forces are there to add $$$ to production costs and list price to add the insurance/protection. I suspect you can set it to cushion start and stop for a variety of inputs. Do you know if the owner ever adjusted it? How big a tractor it was behind before?
It will be a very simple device once you get it apart--be sure the order and direction of plates and clutch discs is maintained in the event there's a ?bell spring? in the mix. There also be coil springs around those bolts--those are more forgiving but maybe harder to initially set.
I'd note how many turns the bolts began a before I disassembled--could also find a "gauge" to reference the housings.
