PTO water pump
/ PTO water pump #1
SuperDutyDave
Bronze Member
Vermont
Deere 5525 Cab-MFWD Deere 244J Loader
Anyone know where one might buy a reasonably priced PTO driven water pump...only ones I have found have been for huge applications and priced in the $5K+ range!
Can't believe you can buy a good trash pump with good lift and good PSI for around $1K but you can't buy a PTO pump for the same or less...it doesn't have a motor!
looking for about 8' of lift, self-priming and sufficient PSI to wash equipment fire fight fill large bulk tank, flood pond surface during winter for skating etc....don't need nor can use a small sprayer type pump insufficent PSI, lift and volume.
Any help would be appreciated...
SD-Dave
/ PTO water pump #2
They make 'em but you won't like the price.
They don't have a motor, but they have a gearbox to speed it up enough to get the pump to do a decent job.
It seems that gearbox is more expensive than a small motor. You can buy 3" gas powered trash pumps off ebay for ~$200. That's what I ended up getting.
/ PTO water pump #3
Dave,
You might check this one out from the Surplus Center. I don't know what the head is on it, but if it won't work they normally have more than what they have listed if you call.
Surplus Center Item Detail
/ PTO water pump #4
After about 20 min of searching I found this
Tractor Supply Company - COMPLETE 6 ROLLER PUMP KIT
Had to call the home office, she transfered me to local store. Priced $122.38
Not in stock.
I bought one in 1994 left it in the box until '98 tried it out and it would blast a grove in hard red clay with my old Satoh idle. It came with pick up and heavy duty pressure hose, brass nozzel and filter on pick up.
I listed "Northern Hyd." as source, however cannot find them now.
I paid $182. I had already planned to get it out and try with Kub B 2910.
Hope it stlll works, after test in 98 I followed storage instructions and poured some oil into pump and turned a few times. It still turns smooth by hand.
Well, whole lot of talk for a little information but hope it helps.
UNUSED KJ 20' BI-PARTING GALVANIZED GATE (A62131)
UNUSED KJ 20'...
203201 (A60429)
203201 (A60429)
(APPROX. 100) UNUSED SDLANCH 6' CORRUGATED STEEL (A62131)
(APPROX. 100)...
UNUSED RAYTREE REDM32 - 32" EXCAVATOR DRUM MULCHER (A62131)
UNUSED RAYTREE...
UNUSED WOLVERINE 8' FORK EXTENSIONS (A62131)
UNUSED WOLVERINE...
Cat CB24B (A60462)
Cat CB24B (A60462)
