Pulling out posts etc.
/ Pulling out posts etc. #21
For shrubs, small trees, and posts under your lift height, a 4-n-1 bucket will do the same job. Just open it up, lower over the offender, close it and lift. Easier to do than say.
I can even get single-trunk trees up to about 15' into my 4-n-1 by turning hard and pushing on the tree with the side of the bucket to make it bend over and spring back up between the bucket jaws.
/ Pulling out posts etc. #22
For removing T-posts, I just use FEL, no chain or anything. Approach T-post from side with studs and, with bucket level with ground, drive forward so that lower bucket edge is making contact with T-post close to the ground. While applying slight forward pressure with tractor curl bucket, which will catch one of the studs on T-post, and out pops the T-post.
/ Pulling out posts etc. #23
Never done this, but an old head told me to put the chain or rope over a large truck rim and that upward pull pops them right out. Some day I'm gonna try that!!
after trying to pull some trees/shrubs one time, my fil suggested the tried and true farmers method. wrap a chain or rope low around the object, up and over a board (i use a 4' long 2" x 12" with a shallow v cut in the top) and pull with tractor/truck/whatever. it will come out so easy you won't know it's done. upward pull does it.
/ Pulling out posts etc. #24
Here is a picture of a jaws type grabber, that looks easy to build.
JJ,
Good pic, and simple build for persons that have enough use for it.
/ Pulling out posts etc. #25
Yep. Probably not more than $500 in material cost for that baby.
/ Pulling out posts etc. #26
The truck rim is effective, if the rim wants to slide forward, just put a wrap on the rim before choking the post.
/ Pulling out posts etc. #27
I have used the truck rim as well. We were moving a fence and needed to re-use the posts, so we didn't want to bend them when pulling them out. Set a truck rim next to the post, choked the post, then pulled horizontally with the winch on my truck. Kept'em straight.
/ Pulling out posts etc. #28
If you need mechanical advantage, run a chain or rope over an old wheel.
Ralph
/ Pulling out posts etc. #29
Man, for four grand it is going to have to pull a LOT of posts.........
That is a rich man"s "toy", and appropriately priced as one.
A rich man would just hire it done. Looks like a contractors tool.
Pull-Behind Spreader Tractor Attachment (A61572)
Pull-Behind...
2005 Peterbilt 378 Day Cab w/ Wetline 834826 (A62613)
2005 Peterbilt 378...
2020 DRAGON ESP 150BBL ALUMINUM (A63569)
2020 DRAGON ESP...
Caterpillar TL1055D (A62177)
Caterpillar...
2020 WIRTGEN WR200 XLI SOIL STABILIZER (A62129)
2020 WIRTGEN WR200...
2007 MACK CTP713 TRI AXLE DUMP TRUCK (A59575)
2007 MACK CTP713...
