Pumps, flow and restrictions.....
   / Pumps, flow and restrictions..... #11
Easily.
Pick up a soda straw and a coffee stir straw. Blow as hard as you can thru the soda straw until you are out of air. Now blow as hard as you can thru the stir straw until you are out of air. Which one resulted in more flow? Which one resulted in you getting more tired / red in the face?
If flow is restricted too much, either the relief valve will pop open, the pump will internally leak back, the pump will cavitate or the pump will grenade. The best result is that the relief will open. If you have the restriction before the relief, the other 3 are in play. None of them results in a healthy pump or a fat wallet, just the time frame to pay varies.
OK everybody....Maybe I wasn't clear enough....my point is very simple......
Here is a detailed example, you guys only have to answer Increase, Decrease or Stay the same?? Just give an "back it up" explanation for your chosen answer.
The system consists of a reservoir, suction line, pressure line, a variable restriction (orifice), and a return line.
We assume no back pressure in return line.
Pump and the rest of the system, is 100% efficient, which means no internal or external leakage.
A FIXED, 10 GPM pump flow (a regular gear pump), is going through an orifice which cross section area is 1/2 square inch, at 500PSI supply pressure.
We also assume a fixed viscosity and temperature. No restrictions (full atmospheric pressure 14.7psi) on suction side.
Prime mover keeps a FIXED rpm.
Now we decrease the orifice area to 1/4 square inch.
Will the flow Increase, Decrease or Stay the same??
   / Pumps, flow and restrictions..... #13
Can some one now tell me how a smaller fitting, QC, bent hose, smaller valve etc (any kind of restriction), on the PRESSURE SIDE of the pump, can decrease flow?????:laughing::thumbsup:
Theoretically in a perfect world of 100% pump efficiency there should not be any flow decrease ( velocity through the restrictions increase ), but as pressure and heat increase so does volumetric efficiency through pump slippage, wear and mechanical tolerances...thus a decrease in pump flow....Never seen 100% efficiency:confused2:
   / Pumps, flow and restrictions..... #14
Sorry you posted this while I'm still learning how to type with one finger:laughing:
   / Pumps, flow and restrictions..... #16
Will the flow Increase, Decrease or Stay the same??[/QUOTE]
Oh; now you asked a question that has no answerer. The temperature and viscosity of the fluid are very critical in calculating the flows. Without those no calculations possible. The type of pipe and it's layout will also be needed.
And don't ask me to do the calculations, my math skills are limited to addition. One plus anuder one plus anuder and so on.:laughing:
And before all else it has to be determined if the original flow rate, pressure and orifice size all agree with each other which will involve more of them calculations!:D
With a PD pump running in a stable mode the flow rate stays the same. It cannot increase or decrease.:thumbsup:
   / Pumps, flow and restrictions..... #17
You dont list the pressure capacity of the pump so an absolute answer cannot be given. The flow will either stay the same or decrease to zero as the pump blows up due the added pressure needed to maintain the positive displacement 10 gpm flow. At 500psi to drive 10gpm thru a 1/2sqin orifice we are talking some pretty viscous fluid. ... thats like -- 3/4" dia :eek:
larry
   / Pumps, flow and restrictions..... #18
If we are assuming pressure will be the same, flow would have to decrease cause restriction would either have to cause a pressure increase to get through the same amount of flow to do the same amount of work.
Pressure does not do work at a stalled position. Flow does work up to stalled position. Now I am fishing.:confused2:
This don't need calculations....it is much more simple than that.....
btw....how do you know temperature and viscosity is very critical at calculations of flow, when you do not know how to make the calculations?? LOL
Actually, temperature and viscosity, will have more impact on pressure than flow....it just takes more force/torque/pressure to push thick fluid through a restriction than it take to push thin fluid through the same restriction....flow is
fixed/constant remember....:thumbsup:
Viscosity indeed have impact on internal leakage....but that factor is disabled in my example.......HAHAHAHA:laughing::laughing:
larry
Sorry larry, you are making this more complicated than it is....you do not even have to think about fitting sizes....OK...any pressure can be considered way below your "pump capacity"....
Grove 4x4 Rough Terrain Hydraulic Crane (A55851)
Grove 4x4 Rough...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2005 GMC Canyon (A57148)
2005 GMC Canyon...
2018 Forest River Flagstaff Pop Up Trailer (A59231)
2018 Forest River...
2016 CATERPILLAR 311FLRR EXCAVATOR (A60429)
2016 CATERPILLAR...
2016 Toro Workman HDX-D Diesel Utility Cart (A59228)
2016 Toro Workman...
