Questions on 2020
   / Questions on 2020 #1
Eddie
Platinum Member
North Alabama
YM2020 & Allis Chalmers 6060
The alternator is charging, at least has 14 volts on battery terminals at 2000 rpm, but the light stays on. Any Ideas?
Is there any cross over for the screw on hydraulic filter? It has a CAPA 145VL-35. Would like to be able to get it local.
Eddie
   / Questions on 2020 #2
Are you sure it's the charging light, (lightning bolt), or is it the battery electrolite level light, (battery w/wavy line thru it)?
   / Questions on 2020 #3
The CAPA 145VL-35 is the OEM filter, I have them in stock.
Danny
   / Questions on 2020
Norm, You are so right, as usual!!!! I had forgotten about reading that here long ago /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif. I found two wires in the harness out by the battery and tied them together and Presto, light went out. Thanks again.
I guess I should run the symptoms of why I think I need a new filter by the experts here. The power lift makes a squalking noise when you raise it, and its very slow. Sound like stopped up filter to you guys????
Danny, I'll email you.
Eddie
   / Questions on 2020 #5
Eddie, even with the screw on filter, you still need to take the screen off and clean it. It could be that also. Either way you will probably want to drain it, and when doing one, you should do the other.
   / Questions on 2020
Dick, is that the round one down in the transmission?
Eddie
   / Questions on 2020 #7
Its the screen like your 1700 has also. I think all Yanmars have them. Even the Deere I bought now, has the same thing, and needs cleaned. When I get to 50 hours I have to replace the screw on filter and clean the screen, like any other built Yanmar. /forums/images/graemlins/grin.gif
   / Questions on 2020
Thanks, I just bought this one today and am going thru a good maintenance before I paint it.
Eddie
   / Questions on 2020 #9
The screen is on the left side, under the brake drum. 2 screws hold the round plate on.
Danny
24in Tractor Backhoe Bucket BT4555 (A52128)
24in Tractor...
2023 JOHN DEERE 30G EXCAVATOR (A51242)
2023 JOHN DEERE...
2017 Claas Jaguar 860 Forage Harvester (A52128)
2017 Claas Jaguar...
2001 DITCH WITCH 8020 RIDE ON TRENCHER (A51242)
2001 DITCH WITCH...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
