Questions on 2020
   / Questions on 2020 #1
Eddie
Platinum Member
North Alabama
YM2020 & Allis Chalmers 6060
The alternator is charging, at least has 14 volts on battery terminals at 2000 rpm, but the light stays on. Any Ideas?
Is there any cross over for the screw on hydraulic filter? It has a CAPA 145VL-35. Would like to be able to get it local.
Thanks
Eddie
   / Questions on 2020 #2
Are you sure it's the charging light, (lightning bolt), or is it the battery electrolite level light, (battery w/wavy line thru it)?
   / Questions on 2020 #3
The CAPA 145VL-35 is the OEM filter, I have them in stock.
Danny
   / Questions on 2020
Norm, You are so right, as usual!!!! I had forgotten about reading that here long ago /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif. I found two wires in the harness out by the battery and tied them together and Presto, light went out. Thanks again.
I guess I should run the symptoms of why I think I need a new filter by the experts here. The power lift makes a squalking noise when you raise it, and its very slow. Sound like stopped up filter to you guys????
Danny, I'll email you.
Eddie
   / Questions on 2020 #5
Eddie, even with the screw on filter, you still need to take the screen off and clean it. It could be that also. Either way you will probably want to drain it, and when doing one, you should do the other.
   / Questions on 2020
Dick, is that the round one down in the transmission?
Eddie
   / Questions on 2020 #7
Its the screen like your 1700 has also. I think all Yanmars have them. Even the Deere I bought now, has the same thing, and needs cleaned. When I get to 50 hours I have to replace the screw on filter and clean the screen, like any other built Yanmar. /forums/images/graemlins/grin.gif
   / Questions on 2020
Thanks, I just bought this one today and am going thru a good maintenance before I paint it.
Eddie
   / Questions on 2020 #9
The screen is on the left side, under the brake drum. 2 screws hold the round plate on.
Danny
2007 MACK GRANITE  TRI-AXLE DUMP TRUCK (A51222)
2007 MACK GRANITE...
2014 UTILITY 53X102 DRY VAN TRAILER (A51222)
2014 UTILITY...
NEVER USED FECON 74in Deck Mulcher FDM74 (A52128)
NEVER USED FECON...
2007 Volvo VNL Truck Tractor (A52128)
2007 Volvo VNL...
377780 (A48837)
377780 (A48837)
2022 INTERNATIONAL MV607 26FT BOX TRUCK (A51222)
2022 INTERNATIONAL...
