Pat's Easy Change Quick link versus Pat's easy change
   / Quick link versus Pat's easy change #21
HappyCPE said:
FWIW Pat's is the hot ticket. That other thing looks like a cheap imitation. I believe in spending good money for good tools... I'd stick with Pat's.
The other "thing" is actually nicely machined and very well made. I bought one but haven't had time to install it yet. It is a simpler design than Pat's but is at least as well manufacturered. Fewer parts to adjust/lose etc too.
   / Quick link versus Pat's easy change #22
I was surfing e-bay the other day and ran acros te quick hitches. One looked exactly like Pat's. The other the less expensive design. Price for the Pat's lookalike was $129 WITH the alignment bar included. I got one and was I surpried when I opened the package and found the insruction manual for "Pat's easy change system.
If this is a copy, this guy has more brass than brains. Don't know the details, but a saving of $70.00 is significant.
   / Quick link versus Pat's easy change #23
I will be taking delivery of 2002 NH TC40 DA in a month or so. It has a telescoping lift arm on one side to make hookup easier. Will PEC be adaptable to that type arm?? I don't have any implements yet to know about length of PTO shaft!!
   / Quick link versus Pat's easy change #24
thatguy said:
As a followup to my own post...
how many ppl ran into a problem needing a longer PTO shaft when using a Pats types quick hitch??
thanks
B
I don't have a Pat's but a Harbor Frieght Quick Hitch. The 4" extension made the pto shaft on my rotary cutter too short. Of course I had shortened it when I first got it, as it stacked when backin' up an embankment. Bought a 3" extension at TSC and although it's a bit wobbly out at the end seems to work ok.
   / Quick link versus Pat's easy change #25
I've wondered if installing a HF Quick Hitch or Pat's type adapters might be a good time to also add a slip clutch, for both the length it adds and for the protection it provides.
   / Quick link versus Pat's easy change #26
Good idea. Has anyone done this? Photos? Who sells add on slip clutches?
2003 McCormick XTX 185 XtraSpeed Tractor (A56438)
2003 McCormick XTX...
2019 CAT TL1055D (A58214)
2019 CAT TL1055D...
John Deere 272 Grooming Mower (A59814)
John Deere 272...
Case 2390 Tractor (A59814)
Case 2390 Tractor...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
2001 Pierce Spartan Model Tilt Pumper Fire Truck (A59230)
2001 Pierce...
