Radiator coolant frozen - help!?
   / Radiator coolant frozen - help!? #11
Put straight anti freeze into the rad.
That will start the melting process.
   / Radiator coolant frozen - help!? #12
20 F is easily cold enough to cause damage. Hopefully there was enough antifreeze in the coolant to prevent that. Warming everything up is about the only way to fix this. One thing that you will have to watch out for even if you don't have any easily detectable damage is in the rad. When the coolant freezes, it expands of course. What can happen is the tubes stretch and swell but don't leak. If they do that, there is a chance the air passages through the rad can be reduced enough to cause heating problems. If that happens you can spend an inordinate amount of time tracking down the source of the problem if you don't twig to what has happened. Just something to keep in mind come the hot season...
   / Radiator coolant frozen - help!? #13
I just purchased a early 80s kubota last week. I went out of town for the last 2 days. While I was gone we got 20 degree weather in south Louisiana! The coolant (apparently mostly water) is frozen when I look in the radiator. Is it ok to start the tractor and let it warm up to melt the ice so I can put actuall coolant in it?
So what was the verdict? Was any real damage done?
   / Radiator coolant frozen - help!? #14
Just wondering why would you put pure antifreeze in a radiator that is already froze, and already a full radiator? Just apply some slow heat and let it thaw out. One more thing was someone said check the mixture on it, it shouldn"t have froze in the first place I would think if it was mixed right. One more thing, I also mix my anti-freeze here in the South 50-50 and never had a problem with it, and I know it gets a lot colder up North. Not trying to sound like a smart alec, just wondering? zman :)
   / Radiator coolant frozen - help!? #15
The theory is to thaw it out slowly by using antifreeze on the ice.
I'm from the north........we always use antifreeze............but Al Gore said global warming was coming...........so eveyone used water in the radiator?:laughing::laughing::laughing:
And to those on here that that live in Australia that were affected by Al's global warming............I really do feel for you...........but elections have consequences.
The USA better wake up also.
   / Radiator coolant frozen - help!? #16
Ahhhh so now i know who to blame, here was me thinking it was mother nature to blame for our floods and fires:mad:, and all along it was Al Gore!!!!!!!!!!!!!!!!!:laughing::laughing::laughing:
Jon
   / Radiator coolant frozen - help!? #17
Back when I was a landscape contractor, we had 2 80's Kubotas, an L2250 and an L2850. My partner (not mechanical) was going from site to site aerating with the 2250 and a Ryan LA72 and apparently was low on coolant. He filled it with water and it froze. I recall replacing the radiator (it was leaking anyway and ultimately was why the coolant was low), but the real issue was the freeze plugs got pushed out all over the engine. I had to tear the engine pretty far down to reinsert on plug, but there were no other issues. We ran it for another 800 hours before selling the business.
Hopefully you will have the same luck!
   / Radiator coolant frozen - help!? #18
Pure antifreeze will actually freeze at a much higher temperature than 60/40 which if my memory serves (most times it doesnt) is the maximum ratio that you can make with ethylene glycol for freeze protection. At this ratio the protection is about -60C and starts to rise again as the ratio is increased all the way to about -10C with pure antifreeze. 50/50 mix is just about as good as 60/40 so that is the recommended ratio.
I suppose a good reason to test the mix is to determine if the mixture froze solid at 20F or just slushed up which would not harm anything. By getting the % glycol you can determine the freeze point.
   / Radiator coolant frozen - help!? #19
back when i was young and stupid..... as opposed to now when im older and stupider... i thought if 50:50 antifreeze was good, 100% antifreeze should be better. i froze the radiator on my Chevy luv pickup when i lived in Montana.
oops.
didnt realize pure antifreeze freezes up easier then a mix.
   / Radiator coolant frozen - help!? #20
I had a friend that thought straight coolant was better too..Till his caught fire from an engine leak...
2014 Cadillac ATS Sedan (A59231)
2014 Cadillac ATS...
2012 NORAM POWER SYSTEMS 100KW GENERATOR (A55745)
2012 NORAM POWER...
Deere 310SK (A57148)
2006 Keystone Laredo 29RL 31ft. T/A 5th Wheel Travel Trailer (A55853)
2006 Keystone...
2021 BMW 1200RT (A55853)
2021 BMW 1200RT...
2020 Deere 50G (A53317)
2020 Deere 50G...
