Removing large pins: Anyone use one of these???
   / Removing large pins: Anyone use one of these??? #21
Doug, I just talked to a mechanic for an excavating company with 30 excavators. He uses a BFH.
And I'll bet he is a healthy young 280 pound weight-lifting gorilla!!! :D
What does one do when they are a short, chubby, overweight, semi-handicapped, half-blind, partly-senile old man??? :(
Dougster
   / Removing large pins: Anyone use one of these??? #23
I have used that tool and smaller versions for pin removal. The smaller one makes short work on driveshaft u-joints. I also have ball joint and tie rod forks for the air hammer. Mine is a Chicago Pneumatics CP-717
   / Removing large pins: Anyone use one of these??? #24
Dougster
You're funny, you make me laugh.
Your CP717 has a bigger shank (.498) than my CP715 (.401) and this particular bit... but yes, this tool is specifically made for U-joints and ball joints. In fact, I could have used this tool a month or so ago when I replaced a ball joint on the hideous old econobox. :rolleyes:
Dougster
Well, it may be funny, but... sadly and unfortunately... it's also mostly true. :eek: The poor old man just ain't what he used to be... so THANK THE GOOD LORD for pneumatic, hydraulic and electric-powered tools! :)
Dougster
   / Removing large pins: Anyone use one of these??? #27
Yep, that is a long stroke gun, I think that will be about as good as it gets with the .401 shank
You could always make one up for that Bosh Brute you have :) I would hate to try and hold it sideways though. :)
Yeah, the electric jack hammer could make very short work of any stuck pin... provided I could find a flat bit, make some sort of guide or template... and then get two other people to hold it steady in the horizonal position. ;)
Let's just hope it doesn't ever come down to that! :D
Dougster
   / Removing large pins: Anyone use one of these??? #29
re; the air hammer by Chi_Car_ GO Pee_Nu_Matic at Sears.
I think Harbor Freight Carries Chic_Pnue, probably at $ears/2 or $ears/3 prices.
I'd try my regular litul air hammer first, maybe with a bit of brass billet in between.
FWIW, etc.
Edit; Just checked that $ears tool, at $60 it is probably the lightweight HF item at
about $20 ;end edit.
FWIW, etc.
Now don't go confusing "Chicago Pneumatic" with "Central Pneumatic"!!! :D
That being said, HF can be a hard place to beat when cheap Chinese crap is all you need and can afford.
We've all been there... even moi!!! :rolleyes:
And yes, I know that a lot of respected brands and models are now made in China too. :( It will be the death of me. :(
Dougster
2017 DRAGON 150 BBL ALUMINUM TRAILER (A53843)
2017 DRAGON 150...
2004 Sterling Acterra Cab and Chassis S/A Truck (A51692)
2004 Sterling...
2000 Ford F-250 Pickup Truck (A55852)
2000 Ford F-250...
2017 Nissan Frontier Ext. Cab Pickup Truck (A54814)
2017 Nissan...
2017 Ford F-550 Crew Cab Enclosed Service Truck with Liftgate (A53422)
2017 Ford F-550...
