Removing trees
/ Removing trees
good advice from all..thanks
Most the the trees I'm cutting have little firewood value.
I'll get up w/ the dozer guy and ask him his preference and get some quotes.
Will try to post some pics soon.
-Greg
Pics
/ Removing trees
I agree with the suggestions of pushing the trees over intact and then cut. It has to be much easier/faster/cheaper. I'm just concerned that the resulting burn pile will be 3 stories high :)
If I cut and THEN get the hired machine in, I can use the FEL to burn as I go over a couple months and have a smaller pile.
Looking at the pics, if all this is piled up at once, will NASA be able to see the flames from space? :eek:
/ Removing trees #23
As has been noted in other threads, pushing over dead trees, or live trees in an area with dead trees or dead branches, can be VERY dangerous. Sometimes the dead tops break off and come back down behind the blade.
Just something to keep in mind.
Ken
/ Removing trees #24
Can you put a person in the photo for scale?
What that looks like to me (guessing scale) I would work through with a hoe or excavator pretty quick.
Good luck.
/ Removing trees #25
The time of year you do this makes a big difference.
I have 100' of 5/16 grade 70 chain and have pulled over scrub oaks up to about 20' diameter at the base with no problems in early spring when the ground is wet enough to be soft, but dry enough to give good traction.
Later in the year, the ground is hard and the same size tree will just laugh at me.
That works fine for 1 or 2 trees. For a large number like you have, the excavator is the only way to go. Think about what you want to do with the wood. Out here, that would all be good firewood. If the trees were laid down, side by side, in several piles so it wasn't too dangerous to cut them up into 18" pieces they could be sold to people who would load them into pickups and drive them off. Gather the rest & burn it in piles. The ash will fertilize your food plot.
/ Removing trees #27
I recently had about 4 acres cleared of mixed size hardwoods, some 30+ inches in diameter. My equipment man used a high lift to knock the trees down. They started a small burn pile, got it REALLY hot, and just kept feeding it all day long. The second worker ran a chain saw and an excavator with a thumb to feed logs onto the fire. The resulting ash pile is about 20 feet long, 8 feet wide and 4 feet tall. I had a lot more trees on my land than you are showing in the pic above.
mkane09
/ Removing trees
Excellent info..I really appreciate all the replies.
-Greg
John Deere 2032R Loader Tractor (A66285)
John Deere 2032R...
2014 DRAGON  130BBL VACUUM TRAILER (A65643)
2014 DRAGON...
2010 John Deere 7330 Premium (A64126)
2010 John Deere...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
2019 FREIGHTLINER M2 4X2 S/A NON 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
2018 SHERP PRO1000 AMPHIBIOUS ALL TERRAIN VEHICLE (A63276)
2018 SHERP PRO1000...
