Repaired 8N stalling when trying to open up the throttle (yes, me again)
   / Repaired 8N stalling when trying to open up the throttle (yes, me again)
I ask because I tried it as full turns, as you describe, and it ran worse. I was thinking I was making too large of changes. I will try again tonight and will also spray some starting fluid where the carb meets the manifold to make sure the vacuum leak is gone.
   / Repaired 8N stalling when trying to open up the throttle (yes, me again) #32
Also check intake manifold to head area for vacuum leaks
OK, checked for vacuum leaks and there are none. I started fresh with the carb and with 5 turns for both the air and main needles it started to run OK. Not great at high RPM -- but OK. Once I got the throttle in a good spot I dusted off the snow and head off to plow the road. I never adjusted the throttle but she worked well and provided plenty of power to get the road clear.
Thanks for the help, guys. I will keep my eyes out for a new carb if she can make it through winter without another major breakdown.
   / Repaired 8N stalling when trying to open up the throttle (yes, me again) #34
5 turns of the main? you have a fuel restriction.. or VERY dirty carb.. or no venturi.
5 turns of the air?
Are you seeing an issue here.
turns OUT on the main enrich the mix.
turns OUT on the idle LEAN the mix.
yer carb is fubar....
   / Repaired 8N stalling when trying to open up the throttle (yes, me again) #35
"yer carb is fubar...." :laughing:
   / Repaired 8N stalling when trying to open up the throttle (yes, me again) #36
he's leaning out one circuit and way over enriching the other. and needing that much adjustment means fuel system desperately needs help.
   / Repaired 8N stalling when trying to open up the throttle (yes, me again) #39
   / Repaired 8N stalling when trying to open up the throttle (yes, me again) #40
I remember when I had a similar issue with my 45 2n it was stalling and losing power loaded or unloaded it ended up being the cheap points I bought and the timing was off because the points were so poorly made.
Preliminary Listing / Full Catalog Coming Soon! (A53317)
Preliminary...
2018 Isuzu FTR Landscape Dump Truck (A59230)
2018 Isuzu FTR...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
2023 RTVXG-850 SideKick (A56438)
2023 RTVXG-850...
PARTS ONLY - 2023 Ram 1500 Classic Pickup Truck - Hemi 5.7L - Automatic Transmission (A56438)
PARTS ONLY - 2023...
