Repairing brakes on Massey 1010
   / Repairing brakes on Massey 1010 #1
UpsideDown
Massey Ferguson 1010
Greetings all from middle GA.
I am working on a Massey Ferguson 1010 compact 16HP machine.
Doing a light overhaul of entire machine, and I am currently on the brakes.
When opening up the covers, one side was full of nasty hydraulic fluid, and the other side full of sludgy rust.
I assumed the seals on both sides could us replacing, in attached picture seal is comprised of parts 25 and 26.
Part 25 is a small soft metal sleeve that goes over the main shaft, and a standard metric seal goes over that.
This part is 25mm ID x 30mm OD, and unfortunately not sold anywhere! I am also trying to be budget conscious.
What I am planning on is bypassing the sleeve by using a metric seal that fits tightly against the main shaft by itself, eliminating that part 25. I have already found good oil seals at this precise measurement (25mm ID x 42mm OD) and have carefully seated them.
Before I fill this machine with $140 of hydraulic oil, do some of you more experienced tractor mechanics find this to be a suitable solution?
Thanks!
   / Repairing brakes on Massey 1010 #2
That sleeve is a wear sleeve and not critical without considering that size tractor will not get a lot of usage. You could put a Speedi-sleeve, 30mm in diameter over that sleeve if it is grooved and salvageable.
If you want to put the sleeve on it now, research Speedi-sleeves and put your diameter to find. They usually have 1 or 2 widths.
As little usage as that size tractor is going to get, your new seal is probably just fine.
Yes, I use it to move dirt and pull fallen trees, it is not heavily used. Thank you much for the information, it will be handy to know if I find these seals leaking down the road!
2012 NISSAN 110 FORKLIFT (A55745)
2012 NISSAN 110...
2001 Subaru Outback AWD SUV (A59231)
2001 Subaru...
2017 Chevrolet Equinox SUV (A59231)
2017 Chevrolet...
2023 Kubota M4-061 Deluxe MFWD Utility Tractor with LA1154 Front Loader (A55315)
2023 Kubota M4-061...
(INOP) 2014 CATERPILLAR 279D SKID STEER (A60429)
(INOP) 2014...
Husqvarna Riding Mower (A56857)
Husqvarna Riding...
