replacing 5 valve bank with a three valve and a 2 valve bank connected
   / replacing 5 valve bank with a three valve and a 2 valve bank connected #41
Pressure is based on the load on the cyl or hyd motor.
That is true on an open center system but not a true statement on a closed center hyd system as pressure is held in hyd lines and machine this thread originated about is closed center.
Well, I was able to work the machine up to operating temp. The new valves work much better, but it seems like I still have drift on the swing. The loader has two swing motors, and I noticed on one of them is a rectangular piece about 5 X 7 X 1 inch thick where the two hoses come in. It has plugs at two corners and another one about midway on the top. It says Eaton, and 2000, and some other numbers that are probably model and serial numbers, but they're hard to read. I'm not sure what that thing is, but could there be a problem in there with internal leakage, causing drift? Or might the I have a problem with the motors causing the drift?
On another note, as I suspected, the old reliefs were probably not set at 1000 as it said on the cap. I have to knuckle in to lift the load, so might have to adjust that upwards.
TEST YOUR BID BUTTON! (A52705)
TEST YOUR BID...
2022 JOHN DEERE 6120M LOT NUMBER 191 (A53084)
2022 JOHN DEERE...
2007 Kenworth T300 Fuel and Lube Truck (A55788)
2007 Kenworth T300...
2006 Chevrolet Impala Sedan (A54815)
2006 Chevrolet...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
Year: 2007 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2007 Make...
