REPLACING ORIGINAL DISKS
/ REPLACING ORIGINAL DISKS #1
spo307
Levittown & Long Eddy NY
kubota L4400
The disks range from 17 1/4 to 15 1/8, there is 28 of them. if I was to replace them with heavier 4.5mm 16" disk, beside loosing 2 inches of depth does anyone see something I am missing. I disked the plots 2 times this past season, and see no need to go deeper than 4 to 5". looking for your thoughts, thanks
/ REPLACING ORIGINAL DISKS #2
Even if your disks started out as 18" I think you'll only lose 1" of depth if you go with 16". The diameter/radius thing. :)
It may well be that the added weight of the thicker disks will make up for it, anyway.
Good luck, Wm
/ REPLACING ORIGINAL DISKS #3
Like willflick said you will only loose one inch. as long as you change out all of them you will be fine.
2013 Mack Granite GU713 Quad Dump (A62613)
2013 Mack Granite...
Caterpillar E200B/EL200B Excavator Service and Parts Manuals (A63117)
Caterpillar...
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A61567)
iDrive TDS-2010H...
2007 Komatsu WA200-5 (A64047)
2007 Komatsu...
1206 (A64280)
1206 (A64280)
(APPROX. 18) CORRAL PANELS (A63291)
(APPROX. 18)...
