Replacying Manual control valve with Electric - need some guidance
   / Replacying Manual control valve with Electric - need some guidance #1
woodlandfarms
Super Member
Los Angeles / SW Washington
PowerTrac 1850, Kubota RTV x900
OK, my Kubota RTVx900 did not come with a hydro tilt bed. A kit is $1000 and has manual controls. I am thinking about purchasing this
https://www.northerntool.com/shop/tools/product_200329586_200329586
To replace this
I think I have this correct. My sytem in the RTV is only 5GPM at 3000 PSI.
Any insight or guidance at this juncture would be appreciated for sure.
   / Replacying Manual control valve with Electric - need some guidance #2
Does your RTV have any other hydraulic functions or does the $1000 include the DC motor, pump, valve, reservoir as an assembly? Reason for asking is that I believe some of the RTV's use a DC power unit for the bed tilt.
Also electric valve would have no feathering they are just on or off.
   / Replacying Manual control valve with Electric - need some guidance #3
And the electric valve doesn't have a float. So when you lower the bed, the full force of the cylinder is applied in the down position. This puts a lot of stress on the whole assembly because at that shallow angle the cylinder is trying to pull against the bed hinges.
I thought this electric valve did have a float...
SOmeone has suggested looking into electric lifts. Will do that on monday.
S/A Fuel Tank Trailer (A59231)
S/A Fuel Tank...
Case 1083 20ft Corn Head (A56438)
Case 1083 20ft...
Forklift (A59228)
Forklift (A59228)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 Ford F-550 4x4 Altec Forestry Chipper Bucket Truck (A59230)
2018 Ford F-550...
