SPYDERLK
Super Star Member
- Joined
- Feb 28, 2006
- Messages
- 10,333
- Location
- VA
- Tractor
- JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
You would be better off using a medium grade Loctite. With anti seize you are significantly overtorquing your bolts.I use an anti-seize compound on my wheel bolts as I want to be able to get them off if necessary. Then, I torque to factory specs...and torque stripe the bolt heads.
As you may recall, your tractor manual does call out to check the tightness of many fasterners (including wheel bolts or nuts) periodically. You shouldn't just torque 'em and forget 'em.
larry
