rim question
   / rim question
thanks guys -
reason I got a compact was that I pull logs from my woods. Since I cut selectivly I need a smaller tractor to get around. But I would like to improve my traction somewhat, so if you have any suggestions I'd appreciate it.
thanks
   / rim question
thanks guys -
thanks
   / rim question #13
Wheel weights, tire chains, front weights, better tires. Those are some suggestions. JC
   / rim question #14
   / rim question #15
My guess is that the 4 holes inthe center are for mounting weights, and the 4 tabs around the edge are for flippin the rim, and changine sides.. to make it wider.. check to see wher ethe rim is mounted to the center.. if there are 4 tabs that look similar.. you have your answer.
Soundguy
   / rim question #16
Soundguy
   / rim question
</font><font color="blue" class="small">( My guess is that the 4 holes inthe center are for mounting weights, and the 4 tabs around the edge are for flippin the rim, and changine sides.. to make it wider.. check to see wher ethe rim is mounted to the center.. if there are 4 tabs that look similar.. you have your answer.
Soundguy )</font>
thanks Soundguy ... I understand you on flipping the tires to make it wider for stability. But what would that have to do with the tabs?
Thanks
   / rim question
Soundguy )</font>
Thanks
   / rim question #19
Some tractors have a rim center that can be unbolted. The rim center is then flipped over and/or wheel is flipped to create different combinations of back set. That said, I don't think you tractor would utilize them for changing the backset.
Try adding liquid and/or iron weights to your tires. The weight will make a big difference.
   / rim question #20
1833 (A57192)
1833 (A57192)
2005 Tennant ATLV 4300 Turf Vacuum (A55851)
2005 Tennant ATLV...
23311 (A51694)
23311 (A51694)
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2016 Nissan Altima 2.5 Sedan (A54815)
2016 Nissan Altima...
2022 Polaris Ranger Utility Cart (A55787)
2022 Polaris...
