rim question
   / rim question
thanks guys -
reason I got a compact was that I pull logs from my woods. Since I cut selectivly I need a smaller tractor to get around. But I would like to improve my traction somewhat, so if you have any suggestions I'd appreciate it.
thanks
   / rim question
thanks guys -
thanks
   / rim question #13
Wheel weights, tire chains, front weights, better tires. Those are some suggestions. JC
   / rim question #14
   / rim question #15
My guess is that the 4 holes inthe center are for mounting weights, and the 4 tabs around the edge are for flippin the rim, and changine sides.. to make it wider.. check to see wher ethe rim is mounted to the center.. if there are 4 tabs that look similar.. you have your answer.
Soundguy
   / rim question #16
Soundguy
   / rim question
</font><font color="blue" class="small">( My guess is that the 4 holes inthe center are for mounting weights, and the 4 tabs around the edge are for flippin the rim, and changine sides.. to make it wider.. check to see wher ethe rim is mounted to the center.. if there are 4 tabs that look similar.. you have your answer.
Soundguy )</font>
thanks Soundguy ... I understand you on flipping the tires to make it wider for stability. But what would that have to do with the tabs?
Thanks
   / rim question
Soundguy )</font>
Thanks
   / rim question #19
Some tractors have a rim center that can be unbolted. The rim center is then flipped over and/or wheel is flipped to create different combinations of back set. That said, I don't think you tractor would utilize them for changing the backset.
Try adding liquid and/or iron weights to your tires. The weight will make a big difference.
   / rim question #20
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 126,771 (A56859)
Year: 2016 Make...
2003 Hyundai Elantra Sedan (A55853)
2003 Hyundai...
(28) 4' FLOURESENT LIGHT CEILING FIXTURES (A54757)
(28) 4' FLOURESENT...
2018 Bobcat T590 Compact Track Loader Skid Steer (A55851)
2018 Bobcat T590...
2019 CASE IH 580S QUAD TRAC TRACTOR (A52707)
2019 CASE IH 580S...
UNUSED X-STAR 101" X 20' LOADING RAMP (A51247)
UNUSED X-STAR 101"...
