Rimguard vs. Methanol
   / Rimguard vs. Methanol #41
And I dont like the Zinc reaction.
"Zinc as in galvanized iron: yields hydrogen gas, which may explode under these conditions"
So much for the "non-flammable" argument. I guess you'll be allright as long as you don't run over any HD galv nails. :p
   / Rimguard vs. Methanol #42
RimGuard has nothing to do with calcium chloride. RimGuard is beet juice sugar solution and is indeed about as non toxic as water and vegetable juice. OSHA classifies it as acceptable for animal feed (!) and states it is biodegradable. I don't know what this other info is about but it seems like possible counterfit.
   / Rimguard vs. Methanol #43
I was having too much fun to want to point this out :D but...
...evidently there are (or were) two products referred to as "Rim Guard".
The link is to a somewhat outdated Ballast Star website (unrelated to RimGuard, Inc.) , and even though the site says "Rim Guard" the actual MSDS is for a product called CITRASTAR-50.
Google strikes again. :laughing:
Here's the MSDS for the "real" RimGuard, which tells you next to nothing about it. Obviously a different compound, though.
http://www.rimguard.biz/Documentation/MaterialSafetyDataSheet.pdf
   / Rimguard vs. Methanol #44
Well, I got the stuff off of their web site. Ballastar. ie RimGuard..
go to this link and check out the MSDS sheet in the upper left hand corner.
BallastStar - RIM GUARD Spec Sheet
does not say a thing about beet juice.. looks like Rimguard is calcium cloride, and a propriatary rust inhibitor, and a dye according to the MSDS sheet.
I for one sure dont know, I am just going by what is on their web site, Unless this is some plot to discredit Rim Guard.
James K0UA
   / Rimguard vs. Methanol #45
I was having too much fun to want to point this out but...
...evidently there are (or were) two products referred to as Rim Guard.
Maybe it is a plot to discredit RimGuard.. I see now what you mean:thumbsup:
James K0UA
   / Rimguard vs. Methanol #46
James K0UA
Check out www.rimguard.biz for the "real" RimGuard info and MSDS
   / Rimguard vs. Methanol #48
YEP, Rimguard is from beets, essentiall beet-juice, nothing more. Made right here in the farmlands of Michigan. Used some on my cereal just this morning - yum!
That link to that other stuff of the same name should be deleted - just leads people to bad information.
According to the MSDS un the OSHA hazards section, it even says it's "approved for animal feed use".
Rim Guard - Liquid Tire Ballast
   / Rimguard vs. Methanol #49
I guess the devil is in the details. Make sure when you request Rimguard from your dealer, you request the "Rimguard" spelled as one word, made from beet juice, by the company w/ the same name, and not the "Rim Guard" as two words (aka Citrastar). Seems like a little copyright infringement going on here.
   / Rimguard vs. Methanol #50
I also noticed something funny on the Ballast Star website where it lists their phony version of è¿*im Guard as:
Biodegradable / Corrosion Resistant / Non-Hasardous. I guess the are being truthful that it is non-hasardous (whatever that means), but it is hazardous.
If you can't even use a spell-checker when developing your website...maybe you shouldn't even bother.:laughing:
2007 International 4300 Dump Truck (A51692)
2007 International...
PREDATOR VACUUM PUMP (A53843)
PREDATOR VACUUM...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
Stainless Steel 1" Spool (A52377)
Stainless Steel 1"...
199049 (A51243)
199049 (A51243)
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
