Road Drag - Driveway Drag
   / Road Drag - Driveway Drag #11
Works OK now. At first it wanted a password to view.
Bruce
So, here's the short story about the zig zaggy things. They are actually precision rack (30 microns), that are scrap from work. I basically used them to replace worn cutting edges.
Here is the long story. Many years ago, my neighbor borrowed the drag and never brought it back. The good news, he dragged the road whenever it needed it. The bad news, he almost wore it out. I originally built it with 3" angle iron blades. I had intended to flip them when they wore down to 2". He wore some of them down to 1".
So I salvaged what I could, bolted on a few new 2 1/2" sections, and bolted on cutting edges over worn sections. It originally had some weight boxes on it, but they trapped debris (leaves, etc.). When I was able to get that scrap rack (2"x3"x 1 miter), it was the perfect solution for robust cutting bars and weight.
Because I crown the road, all the weight and wear is on the right hand side. The rest doesn't wear too bad. The ends of the two rear blades wear a bit over time which is perfect because it helps feather the edges.
I could have put the scalloped edges down to act as scarifiers, but I really don't need it to be that aggressive. I have a box blade I could use for that if I needed to, or I could bolt a scarifier blade to the drag if I wanted to.
I don't know if the video shows it, but that drag really leaves a nice smooth finish, and that guide wheel maintains the crown.
I see CNC in your handle. We have three 11 axis CNC Mill Turn machines in our plant.
   / Road Drag - Driveway Drag #14
AB- Nice work!!
   / Road Drag - Driveway Drag #15
Thanks for the explaination.
At work I program, set-up, and run 3 swiss lathes. Two Citizen L25's ano one Citizen M20.
   / Road Drag - Driveway Drag #17
Great looking drag. Where I used to live in Fla. on a sand road, there was a similar one that someone built from railroad ties. It was parked beside the road at either end and when it would get too washboardy, somebody would hook on and drag it back and forth a couple times and park it until the next time. At the price of steel today, that might be an option.
   / Road Drag - Driveway Drag #18
That's they way they used to do it.
King road drag - Wikipedia, the free encyclopedia
   / Road Drag - Driveway Drag #19
I will build one too, thanks very much for showing how its built The video in action is great, really shows that this thing does what I need.
   / Road Drag - Driveway Drag #20
Great video. looks like it does a really nice job on your roads.
Eddie
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2020 Deere 50G (A53317)
2020 Deere 50G...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A56438)
2020 Westfield MKX...
Mini Jack Daniels Truck (A55853)
Mini Jack Daniels...
2022 John Deere 1025R (A53317)
2022 John Deere...
John Deere 6110M (A53317)
John Deere 6110M...
