Rotary mower stalling
   / Rotary mower stalling #21
PTO inside the tractor is slipping. See my earlier post. It's not the mower or the external shaft. Do you have an independent PTO or a live PTO?
Post #13....OP said: "I have an independent pto."
So will adjusting the PTO lever fix this?
Yeah, I saw those threads. I will try that. Thanks!!
How hard is it to replace these clutches if they ever fail?
   / Rotary mower stalling #26
Most the time you have to split the tractor....in half. It is better to make a simple adjustment.
I tried adjusting the pto clutch linkage...couldn't. The thing is in a very tight spot and I can't even get a wrench on good enough to loosen the jam nut.
I also noticed that if I put the PTO lever halfway...the pto will spin faster and mower wont bog down as easy.
If I engage the pto fully..the pto will be slow and mower will bog down.
I made two videos. You can tell the difference between the half and full engaged pto
Fully engaged pto clutch john deere 5205 - YouTube
Half engaged pto John Deere 5205 - YouTube
Is there any wrench I can use to get in this tight spot?
   / Rotary mower stalling #29
Maybe a crows foot;
or can you pull a pin or two and drop it out to adjust and then repin it.
I can't even reach the pin. My hands are too big.
I will try a crowsfoot.
Thanks.
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
Snorkel Uno 41D 4x4 Articulating Boom Lift (A59228)
Snorkel Uno 41D...
2024 JOHN DEERE 250P EXCAVATOR (A60429)
2024 JOHN DEERE...
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2018 PRINOTH...
2014 INTERNATIONAL PROSTAR+ (A58214)
2014 INTERNATIONAL...
