Rotory Stump Cutter
   / Rotory Stump Cutter #1
nspec
Platinum Member
Southern Rhode Island
Kubota B2630, '53 Farmall Super H, '47 Farmall AI, '44 Farmall A
   / Rotory Stump Cutter #3
It's a funny link for some reason. Click on the part that says 'youtube', not the 'john deere' part.
edit: sorry to repeat. bcp beat me to the post.
   / Rotory Stump Cutter #5
Yeah, I've seen videos of them before...Wonder if they make one to fit a BX??? :D
   / Rotory Stump Cutter #7
Cool machine. But i wouldn't want one on my tractor. looks like a lot of stress on the tractor
   / Rotory Stump Cutter #9
Why do they have them rotating CCW?? Doesn't seem like it would make any difference to rotate either way, but both of those models are shown going CCW like there may be some advantage rotating that direction??
I bet they cost a chunk of pocket change though!
   / Rotory Stump Cutter #10
That a CAT2? Lot of power being geared down and transferred to ground there.
   / Rotory Stump Cutter #11
I saw those videos a while back. Theres several models. Some are like a big core drill. Some mounted on mini Excavators.
http://www.ferrirotor.com/fotogallery.html
Theres a video of one working in a tree farm. Could see it in that use after the trees are cut.
Pretty sure they build a custom heavy duty subframe from front to back to run the auger. Spreads the load around to the whole machine. I also think that Bi-Directional PTO is required as well.
A different brand mounted on a Mini : http://www.youtube.com/watch?v=-jTMXwWuJ5w&feature=related
   / Rotory Stump Cutter #12
Seems like the debris is much larger than a regular stump grinder and would take longer to decompose. I am sure it has its place though.
   / Rotory Stump Cutter #13
Very impressed with the speed of operation. I removed a stump the size of the one in the first video with a bobcat mounted grinder and it took about an hour.
2019 KOMATSU D65WX-18 CRAWLER DOZER (A60429)
2019 KOMATSU...
2016 CATERPILLAR M322F MOBILE EXCAVATOR (A60429)
2016 CATERPILLAR...
Boat (A59231)
Boat (A59231)
2011 FORD F-550 (INOPERABLE) (A55745)
2011 FORD F-550...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2015 Freightliner 122SD T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Freightliner...
