Safety Tips
   / Safety Tips #71
Re: Safety Tips - Tractor Overturn Hazards
Most of the time, I don't pay any attention to my tiltmeters because I'm on ground that I know doesn't have much slope, but I was darned sure looking at them frequently Sunday when I was mowing on a couple of stock tank dams (OK, pond dams for you northerners/w3tcompact/icons/wink.gif).
Bird
   / Safety Tips #72
Re: Safety Tips -Preventing Tractor Rollovers
   / Safety Tips #74
Learn from Others Who Paid the Ultimate Price
"Tractor -- rear upset, pulling a stump"
"Extra rider fell off tractor..crushed by tractor tire"
"Tractor upset to the rear pulling a tree"
"Tractor rolled over on road pulling a load of lumber on wagon"
"Cut corner too short on road, rolled over in a ditch"
"Died trying to pull fence post with tractor..hit operator"
"Extra rider crushed in side roll over in a gravel pit area"
"Tractor operator was run over trying to start tractor from ground"
"Extra rider fell off tractor, struck by fail mower"
"Tractor slid off icy roadway and rolled over crushing operator"
"Extra rider fell off and struck by field mower"
"Tractor side roll over, operator found in roadway ditch under tractor"
Readers might make the mistake of saying that it can't happen to them because they are careful, it only happens to the other guy. But the facts show that a tractor accident can happen to anyone, evaluating risks and being prepared in the event of an accident is the key to safe tractor operation.
Never take a risk that you know you shouldn't! This includes taking extra riders on the tractor, even for just a short drive; using a tractor for a job where a bulldozer is needed, such as pulling stumps or large rocks; etc. If you feel there is a risk involved in a task, then there likely is and other options should be considered.
Remember, accidents do happen, even to the safest tractor operator. To reduce the risk to yourself, take necessary precautions.
{from the web}
   / Safety Tips #75
Re: Safety Tips-Chainsaw Kickback
http://www.osh.dol.govt.nz/kidz/gore/images/kneck.jpg
Bar nose kickback is one of the more common causes of serious chainsaw injury accidents
Kickback may occur when the moving chain at the nose or tip of the guide bar touches an object, or when the wood closes in and pinches the saw chain in the cut. Tip or bar nose contact can, in some cases, cause a lightning-fast reverse reaction, kicking the guide bar up and back toward the operator. Pinching the cutting chain along the top of the guide bar may push the guide bar rapidly toward the operator. Either of these reactions may cause you to lose control of the saw, which could result in serious personal injury to yourself or to bystanders.
The top of the tip of the chainsaw guide bar is known as the KICKBACK DANGER ZONE. When contact is made with an object such as a branch or a log, there is a danger of a sudden bar nose kickback reaction.
Modern chainsaws are equipped with a variety of devices intended to reduce the risk of injury from kickback or from other causes. Among these are the chain brake, the front (left) hand guard, the bar tip guard and low or reduced kickback saw chain and guide bars. To assure the protection afforded by these devices is maintained, it is important your chainsaw is properly and fully assembled, and that all components are securely attached and functional.
Chainsaw Kickback
Kickback from chainsaws
It’s a good idea not to attack yourself with a hi-revving chainsaw. This is what happens when a chainsaw "kicks back". One in every 12 forestry work accidents is caused by chainsaw kickback, so if it can happen to a professional tree feller it can happen to a less experienced chainsaw user as well. Kickback happens while, in making a cut, the top of the bar nose contacts a solid object or is pinched. This causes the guide bar to fly back towards you. A chainsaw is designed to cut through wood but it will slice through muscle and bone with ease, severing nerves and arteries in the process.There are ways to reduce the likelihood of kickback, such as by using an anti-kickback chain and not using the tip of the guide bar for cutting.
{from the Web}
"You are what you eat, drink, think, say and do..."
<P ID="edit"><FONT SIZE=-1>Edited by Muhammad on 07/10/01 01:49 PM (server time).</FONT></P>
   / Safety Tips #76
Re: Safety Tips - Rotary Cutters/Mowers
Safety with Agricultural and Industrial Rotary Mowers
An accident with a rotary mower can cost you your life! Following safety practices, using proper equipment correctly and keeping equipment in good repair are the best accident preventives.
A rotary mower can also injure innocent bystanders, so it is important that they, too, be alert and follow safety rules.
Many accidents have happened when basic safety rules weren't followed:
* A limb knocked a passenger off a tractor pulling a rotary mower. Before the tractor could be stopped, the rotary mower ran over the victim.
* An operator accidentally hit a stump while clearing out brush. He fell from the tractor and was run over by the mower.
* While watching a rotary mower in operation, a bystander was severely injured by a piece of barbed wire thrown by the mower blade.
These accidents, and many others, could have been prevented had safety practices been followed.
Safety Practices for Rotary Mowers
* Use the right type of mower for the job...
Know the job you are going to do, and use the correct kind of mower for it. For example, don't try to cut brush with a mower designed only for forage. You could be exposed to hazards caused by machine failure. Use heavy-duty blades where they are needed, and use a large enough machine to do the job properly. Check your operator's manual for the type of job your mower is designed to do.
* Keep others away.
Don't allow extra riders on your tractor, and keep other people out of your working area. Serious injury or death can result from falling off the tractor and being run over by the mower, the tractor wheel or being hit by a thrown object.
* Watch for objects that can be thrown by the mower...
Watch for objects like tin cans, stones, wire or other items that could be hurled by the mower blades. These can cause serious injury.
* Be alert to obstacles..
Obstacles such as ditches, rocks, and stumps can throw you off the tractor or cause a tractor upset. Be especially alert when objects may be hidden by tall grass, weeds or brush. If your tractor is equipped with roll-over protection, use the seat belt.
* Disengage pto, set brakes.
Disengage the power take-off (pto) and set the brakes before dismounting your tractor for any reason.
* Be sure blades are stopped ...
Many rotary mowers have blades that continue to rotate for some time after the pto is disengaged. Be sure they have stopped turning before approaching the mower.
* Be careful when turning sharp corners...
On pull-type mowers, the rear tractor wheels could catch the mower frame and throw it toward you. With three- point-hitch mounted mowers, the mower swings outward when you make a turn. Front wheel weights may be needed to help you keep control.
Maintenance for Safety
Before operating your mower, familiarize yourself with its maintenance procedures. Study your operator's manual carefully.
Begin your pre-operational check by making sure the power take-off is disengaged and the engine is shut off. Look for loose nuts and bolts.
Blade sharpness is a key to efficient mowing. Inspect the blades often, and when they become too dull for additional sharpening, replace them. Dull blades can be dangerous. because mowing will be more difficult. Hazards increase when you are having problems with the equipment.
Rotary mowers are often equipped with runners and safety chain guards. To avoid excessive wear on the runners, keep the mower just high enough so that it doesn't ride on the runner shoes.
The chain guards reduce the possibility of objects being thrown from under the mower. Be sure chain guards are maintained and kept in place. If you must remove them or raise them for certain crops, be sure to replace or readjust them as soon as you are finished.
PTO shafts should be protected by shields or guards. Keep them in place on the machine. Always replace shields and guards after maintenance or repair jobs are complete.
____{from the web}____________________
   / Safety Tips #77
Re: Safety Tips-Hydraulic Systems Safety
Hydraulic Burn Injuries -
Whenever hot hydraulic oil is permitted to exhaust to atmosphere, it can come into contact with the skin. In most cases the volume is unknown, and the velocity can be extremely high, leaving the outcome unpredictable.
Hydraulic systems generally operate at temperatures ranging from 130º F to 180ºF under normal operating conditions. These temperatures can easily exceed 250ºF if there is excessive wear in a system.
Petroleum-based hydraulic fluids become hot during operations. A heated petroleum-based hydraulic fluid presents a considerable fire hazard, particularly in those processes where ignition sources are usually present.
A typical petroleum-based hydraulic fluid has a flash point that ranges from 300ºF to 600ºF, and an auto ignition temperature of 500ºF to 750º F. When hydraulic fluid is purposely or accidentally discharged under high pressure an easily ignitable fine oil mist is sprayed into the surrounding area. If the mist reaches an ignition source the result can be a torch-like ball of fire, or if the mist is confined, it can result in and cause a violent explosion.
Case History -
According to a report from the Workers Compensation Board of British Columbia, a 61-year-old bulldozer operator was sprayed with hot hydraulic oil when a hydraulic hose unexpectedly ruptured. He later died from his burn injuries. This proves that hydraulic oil, at normal operating temperature, can kill you.
At What Temperature Will You Burn?:
According to information we received from a very helpful individual at the Intermountain Burn Center in Utah, a person’s skin will scald at 120ºF. It will take approximately 2 to 3 minutes to receive a 2nd degree burn at this temperature if the heat is sustained.
If the temperature is increased to 140ºF, the average operating temperature of a hydraulic system, it takes 1/2 to 1 second of sustained heat for a 2nd degree burn. Oil is inclined to adhere to ones skin, consequently, the longer the contact, the deeper the burn.
Burn injuries are the worst type of injury from a rehabilitation and cost point of view. The rule of thumb is; one day in a hospital for each 1% of burnt body area.
The costs associated with the treatment of burn injuries are astronomical: a burn that covers 30% of total body area can cost as much as $200,000.00 in initial hospitalization costs and physicians fees. For extensive burns, there are additional significant costs, which include costs for repeat admission for reconstruction and for rehabilitation.
~~~from the Web~~~
   / Safety Tips #78
Pinhole Leak Injuries
Probably the most common injury associated with hydraulic systems is the result of pinhole leaks in hoses. These leaks are difficult to locate. A person may notice a damp, oily, dirty place near a hydraulic line. Not seeing the leak, the person runs a hand or finger along the line to find it. When the pinhole is reached, the fluid can be injected into the skin as if from a hypodermic syringe.Immediately after the injection, the person experiences only a slight stinging sensation and may not think much about it. Several hours later, however, the wound begins to throb and severe pain begins. By the time a doctor is seen, it is often too late, and the individual loses a finger or entire arm.Unfortunately, this kind of accident is not uncommon. To reduce the chances of this type of injury, run a piece of wood or cardboard along the hose (rather than fingers) to detect the leak.
{Entry Wound...}
~~~from the Web~~~
   / Safety Tips #79
Exhausting High Pressure Oil to Atmosphere Can Cause Skin Penetration Injuries -
In addition to the risk of suffering burn injuries one must consider the consequences of high-pressure oil penetrating the skin.
According to the "Occupational Injuries Handbook," oil can penetrate the skin at pressures as low as 100 PSI -
"The force of injection, which can range from 100 to 1000 pounds per square inch, causes the fluid to track along the planes of the tissue and flexor tendon sheath. In this way, it can travel from the fingertip throughout the hand and even proximally into the forearm."
http://www.tractorbynet.com/forumfiles/34-73690-Fluidhandinjuryexitwound.jpg
{Exit wound-from a pinhole leak...}
~~~from the Web~~~
<P ID="edit"><FONT SIZE=-1>Edited by Muhammad on 11/24/01 08:01 AM (server time).</FONT></P>
   / Safety Tips #80
bleck! Yuck! gag!/w3tcompact/icons/tongue.gif
Now I am gonna have to find that picture of the guy who got hit in the neck by a chainsaw kickback to get you back for showing me this!
2005 FORD F-450XL SUPER DUTY DUMP TRUCK (A52707)
2005 FORD F-450XL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59905)
2018 VOLVO VNL...
John Deere 2640 2WD Tractor with 146 Front Loader (A57024)
John Deere 2640...
Case-IH 370 Steiger (A57148)
Case-IH 370...
