Saplings and brush around pond banks. Suggestions?
   / Saplings and brush around pond banks. Suggestions? #81
New tractor owner looking for some advice. I have an issue around my pond with some plant I can't recognize that likes to grow right on the water's edge. They can get quite large if left unchecked. I let them get a bit out of hand last summer and had to spend many hours with the chainsaw addressing the issue over the winter. Now there's small stumps and the freaking buggers are starting to come back again. I'd rather not have to back a bushhog up and down the bank over and over and larger the batwings seem like a bit much for my needs. Anyone have any suggestions? would a flail work well?
Note, my tractor doesn't have remotes or a 3rd function, but I've considered adding them, if needed.
Also, I'm aware of the laneshark, but I'm seriously wondering if it's worth the price. For most of my cutting needs, a bushhog would work very well. I only need something like this for the pond banks.
The pond is roughly 5 acres. Some of the bank edges have a ~1 - 2' drop to the water.
Generally anything you cut, chop, lop or whatever will only grow back. If you want to truly eliminate the problem you must simply KILL them. Mentioning a chain saw makes me thing these a bigger than twigs. I have had very good luck drilling a 3/8 hole at a downward angle and squirting a some undiluted brush killer. It will kill the plant and prevent any additional 'suckers'. Weed killer is dangerous to aquatic life. Don't go hosing that stuff around.
   / Saplings and brush around pond banks. Suggestions? #82
Not necessarily. Here in the northern hardwood forest we have maple shoots everywhere which grow like weeds. We found if we cut them ever year while low, grasses will take over and ****** the new tree shoots. But the OP type of brush and climate, I can't comment on what happens there..
   / Saplings and brush around pond banks. Suggestions? #83
Another tool that surprised how useful I got about a year ago was a Dewalt 20V polesaw. 8” bar cuts fast and good battery life. Easier than a chainsaw. The reach helps a lot. Keeps me out of the danger zone. Bigger stuff don’t have to cut all the thru will break when grappled. Once a load is grappled easy to trim to carry off. Mostly use with two pole sections. A third section for longer reach. Can carry on the tractor. Chain stretched a lot at first but improved over time. Nobody has mentioned yet is I have a lot of creek banks to maintain.
When I used to cut hay routinely cut 1.5” saplings or branches with a sicklebar mower. Live cut easier than dead. Bigger was iffy to cause tooth damage. HiSpeed MF, belt driven. Always wanted to modify to ssqa mount, FEL, hydraulic powered for a ditch and lane cutter. With HST and better visual up front would help. Road mowing crews used mid and rear sickle bars growing up.
   / Saplings and brush around pond banks. Suggestions? #84
From time to time I have the same problem. Used extra strength round-up. Have not noticed any problem with fish/turtles.
   / Saplings and brush around pond banks. Suggestions? #85
Think treating stumps with Tordon is part of solution....they won't come back, but new seedlings need to be treated before they get too big and that means mechanical removal or spray.
   / Saplings and brush around pond banks. Suggestions? #86
I second the Tordon route. We were having what looked like Willow bushes. If you cut them, make sure you get it all out of the water as the cut offs will start new growth elsewhere in your pond. Otherwise, cut them flat and coat the stump with Tordon. Then wait fore the water to drop, assuming a hot, dry summer, then cut the stumps down tight. I've been know to hit them again with Tordon to make certain they do not come back.
   / Saplings and brush around pond banks. Suggestions? #87
I have an M18 Milwaukee Pole saw and a Stihl MS110 brush cutter, Makes good paths for the tractor and getting around the larger dead trees to take them out.
Tractor with toothbar to rip up honeysuckle and other woody brush by the roots. Backhoe if needed for the bigger stumps.
I try not to spray much except the stiltgrass which just starting taking over any disturbed soil and open space in the area.
   / Saplings and brush around pond banks. Suggestions? #88
Has anybody ever tried mowing the trees/willows off and then getting some goats?
   / Saplings and brush around pond banks. Suggestions? #89
I have the same problem with two sides of my 3 acre pond. I have found the best method is the bush hog backing up and down the slopes to the water. I plan to rent a Billy Goat next month to mow about 1/4 acre inside the fence from the pasture which is rutted and difficult to mow with the tractor/rotary cutter. Considering the cost of new equipment for a job such as this, you might also consider hiring someone to do the hard work. I am usually able to hire someone by the day to this type of work for a few hundred dollars.
   / Saplings and brush around pond banks. Suggestions? #90
Sickle bar mower...its the only thing that will give you the reach you need and keep you clear of the bank (other than hydraulic flail on the end of hydraulic arm). I grew up using those on our farm's creek banks. They work really well...not sure way they have fallen out of favor. It's probably because you can't abuse them the way you can with a bush hog. They are really meant for maintaining a field. I've used them in our fields along the creek where the brush was 10 feet tall, but nothing was over 2" in diameter.
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
378747 (A51572)
378747 (A51572)
TITAN - SET OF 18.4R46 NEW AG TIRES (A52748)
TITAN - SET OF...
2014 KENWORTH T680 (A52472)
2014 KENWORTH T680...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
