School me on the Tombstone
   / School me on the Tombstone #31
With a $500.00 budget, you could get a Lincoln AC225 and a Lincoln flux core wire welder for your smaller stuff. Gloves, shield, sleeves, etc aren't that expensive unless you go for those auto-dark shield (which I am not a fan of).
   / School me on the Tombstone #32
the auto darkening hood is the single greatest piece of welding equipment i ever purchased. It has improved my meager welding skills tremendously. No more constant flipping hood up and down.
you'll never pry that hood out of my hands...never i tell you :laughing:
Yes, I am certian I will purchase one of the auto darking hoods. I remember the only welding I did back in high school trying to shake my head to get it to flop down right and start my arc etc. Not that coordinated or just need a lot more practice.:laughing:
   / School me on the Tombstone #34
I was going to purchase a Thumbstone at Canadian Tire ( Canadian equivalent to Lowes) this week as they bare on sale at 289.$ but after reading the posts I am more confused than ever , cause there alot of different opinions here.:confused::confused:
   / School me on the Tombstone #35
If you are patient, you can pick up a AC/DC for around $120. The DC made welding much easier.
Ken
Yes patience will be needed, I got super lucky though, the first day I seriously looked for an AC/DC machine, I found one on craigslist for a great deal on a nearly brand new machine. A miller Thunderbolt.
But since then I have not seen any AC/DC machines except expensive gas powered portables, great deals on the portables but still expensive.
I have turned down free AC welders as I didn't need another, one was a brand new Tombstone sitting in a ladies garage, her husband bought it and never used it. Gave my AC away as well, so it shouldn't be hard finding an AC for a good deal.
I don't know if I'd call an auto darkening helmet the greatest pc of welding equipment, but it does make things a little easier, one less thing to have to think about. For me I wont go back, I delayed getting one until just last year, now I definitely do appreciate it.
JB
   / School me on the Tombstone #36
I researched the powerarc 200 and that seems to be a pretty good deal! My only fear is I can not test a used unit. I think I may pickup a really cheap flux 100 or 125 amp mig and a unit like the powerarc.
If you buy the PowerArc 200, don't waste your money on a 120-volt flux core wire feeder!
Far as the PowerArc 200, now that is one slick little machine! Most likely the best $300 + you'll spend on welding equipment.;)
I am in the same boat. lol. Every post I read I change my mind.
This afternoon I was positive I wanted a cheap Northern tool 125 amp mig and a lincoln 225, but I am sure I will change my mind in the morning. The $289 is a standard price for the lincoln 225 machine at Home Depot.
Shield Arc,
You think the powerarc can do the light gauge materials as well?
   / School me on the Tombstone #38
Shield Arc is a good guy to ask about thin material. But remember that he is a pro and can weld things that "normal" folks can't.
I have used 1/16" 6013 with the PowerArc 200 on thin stuff without a problem. Other than it is a pain to get the amps just right to melt just right. That is a weldor problem rather than a welder problem.
   / School me on the Tombstone #39
I would not buy a brand new AC225, as you can find way too many used ones for a third the price or less of a new one. These things a darn near indestructable and your kids will be using this same welder as there is just so little to go wrong on an AC power unit. If it works when you buy it chances are it will continue working for decades to come. Even if you decide you want a better welder later you will be able to easily sell it to recoup your minimal investment - it will never depreciate. Plus, AC is the one area that works best with the Carbon Arc torch anyway so it is worth having for that alone.
Mig is not a bad idea either for thinner metals as a novice can weld much thinner metal with mig, but I would skip the Northern tool and go with an affordable 120 volt Hobart or Lincoln. I myself would buy the Mig unit new as there is much more to go wrong in a mig. (I myself have a Lincoln SP-135). Realistically though, 24 gauge to 1/8" metal as the normal easy working range of a 120 volt unit, 3/16" metal can be done with some beveling and multiple passes, and 1/4" or bigger can be done in a pinch too with beveling and several passes. Mig does not like rusty metal at all. Mig will not work outside either as your shielding gas get blown away. You can switch to gasless flux core and not use gas but then you can not weld as thin as metal with flux core and flux core is terrible for use in autobody work - makes the paint bubble. Going to a 220 volt mig will cost more, but does add thicker metal to the mix.
   / School me on the Tombstone #40
I'm just a so-so self taught welder that used to have a cheap AC welder, and my welds looked like it. they held, but were ugly.
I broke down about 16 years ago and bought an ac/dc with reverse polarity unit...it wasn't cheap but man, my welds sure improved ... without me doing anything.
Ive actually Had a professional welder friend of mine tell me that my welds do look very good. Nothing has ever split apart.
Mind you, id never trust my welds on a trailer frame, but here around the ranch they are fine.
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
UNUSED FUTURE FT-XJ7T 7 TON 46" HYD THUMB CLAMP (A51248)
UNUSED FUTURE...
Adams 5 Ton HC Spreader (A53472)
Adams 5 Ton HC...
2000 PETERBILT 357 6X6 DAY CAB ROAD TRACTOR (A51406)
2000 PETERBILT 357...
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
JOHN DEERE CP690 LOT IDENTIFIER 70 (A53084)
JOHN DEERE CP690...
