   / Share Pics of People Hauling or Towing Something Wrong #17,081
I also should mention the straps on the truck are 1" commercial grade rated at 2300 pounds each. They are much thicker than cheap 1" straps. They are expensive but it's worth it because they fit the anchor points in the truck bed. And it's not squatting. I don't like how those 2500HDs look up high with the square wheel arches and the nose down slope. So I put drop shackles on the rear to level it and an autolevelling air bag setup so it won't bottom out when loaded.it sits the same empty. It handled that load just fine. I stopped at a state scale that was closed on the way home and the truck was under the GRAW and right at capacity on the trailer.
   / Share Pics of People Hauling or Towing Something Wrong #17,088
   / Share Pics of People Hauling or Towing Something Wrong #17,089
^ photoshop.
That rear-steer combine on the bridge is funny. What a pickle, no room to steer away from the edge.
   / Share Pics of People Hauling or Towing Something Wrong #17,090
^ photoshop.
Crank the wheel hard to one side, then the other to push the back end away from the wall using the steering, then back up until the front end clears.
Aaron Z
New/Unused Agrotk YC-26G Sawmill (A57453)
New/Unused Agrotk...
(1) HD 24ft Free Standing Corral Panel (A57453)
(1) HD 24ft Free...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
2014 Lincoln MKS Sedan (A56859)
2014 Lincoln MKS...
Forestry Truck Grapple and Frame (A55851)
Forestry Truck...
