   / Share Pics of People Hauling or Towing Something Wrong #17,081
I also should mention the straps on the truck are 1" commercial grade rated at 2300 pounds each. They are much thicker than cheap 1" straps. They are expensive but it's worth it because they fit the anchor points in the truck bed. And it's not squatting. I don't like how those 2500HDs look up high with the square wheel arches and the nose down slope. So I put drop shackles on the rear to level it and an autolevelling air bag setup so it won't bottom out when loaded.it sits the same empty. It handled that load just fine. I stopped at a state scale that was closed on the way home and the truck was under the GRAW and right at capacity on the trailer.
   / Share Pics of People Hauling or Towing Something Wrong #17,088
   / Share Pics of People Hauling or Towing Something Wrong #17,089
^ photoshop.
That rear-steer combine on the bridge is funny. What a pickle, no room to steer away from the edge.
   / Share Pics of People Hauling or Towing Something Wrong #17,090
^ photoshop.
Crank the wheel hard to one side, then the other to push the back end away from the wall using the steering, then back up until the front end clears.
Aaron Z
2013 John Deere 5075E (A57148)
2013 John Deere...
2017 MACK  CXU613T (A58214)
2017 MACK CXU613T...
2020 DRAGON ESP...
WOOD GRABBER FOR MINI EXCAVATOR (A58216)
WOOD GRABBER FOR...
13hp Honda 7500 Watt Generator (A57454)
13hp Honda 7500...
ELECTRICAL HOUSING BOX (A58376)
ELECTRICAL HOUSING...
