She's DONE! - Power Rake Build
   / She's DONE! - Power Rake Build #31
Dave, I have a couple more questions. How long are your teeth, and what material are they made from? Secondly, does anyone have a source for a PTO shaft with slip clutch? I have priced one out locally,seems pricey at over $500, looking for other ideas. I have all the pieces for my power rake build except the pto shaft.
Very nice. I can already see a hydraulic motor set up in the works for one I would like to build. Did you use carbide for the teeth?
Nah, I used steel teeth....thought about it but the Cost/Reward just didnt pencil out for me...I figured if I wore these 2" nubs out chances are I've done EVERY Project I wanted to do and done every yard in the town as well...so she'd be "Paid for" to the point I could go out and buy a "genuine harley" drum with carbide nubs...ORRR...Seeing as how i built the whole bleepin thing myself in the first place, just welding up new nubs on the drum would be a simple little "maintenance" chore :D
Teeth are 2" long, Steel...
PTO Shaft with slip clutch....TSC Has one labeled as a "Tiller shaft" for 219 or so...
I got the clutch itself from Agrisupply...because I used an "industrial" gearbox it didnt have a splined input shaft...Industry uses Keyways... so I had to buy a smooth bore "generic" clutch and have the female side broached for the keyway and then buy the Yoke type "input plate" because I couldnt find an off the shelf clutch which would work...the driveshaft itself came from eBay... Total cost of my driveshaft with clutch, etc.. was $185.00 and I have a "lefotver" smooth 1 3/8" male input plate to sell on eBay shortly...
   / She's DONE! - Power Rake Build #34
I am impressed. I do a lot of "hobby" welding and fabricating, but I don't think I have the ability to do what you did. Outstanding !
   / She's DONE! - Power Rake Build #35
Nice job, real nice job. You do good work.
   / She's DONE! - Power Rake Build #36
Since you seem to enjoy torturing yourself, make up a whole new drum so you'll have a ready spare :)
One very nice unit you built.
   / She's DONE! - Power Rake Build #38
Great job!!
BTW, Did you weld it up with that little Maxstar 150?? I should say BIG little Maxstar 150!
   / She's DONE! - Power Rake Build #39
Hi, I was wondering how those slip clutches work?
Harley Davidson (A56859)
Harley Davidson...
(INOP) FARMALL TRACTOR (A52708)
(INOP) FARMALL...
1987 FORD F-600 FLATBED TRUCK (A58374)
1987 FORD F-600...
500BBL FRAC TANK (A58214)
500BBL FRAC TANK...
(INOP) 2019 KOMATSU D61PX-24 CRAWLER DOZER (A52705)
(INOP) 2019...
1985 Ford Ltl9000 Tender Truck (A56435)
1985 Ford Ltl9000...
