Sims Cab with Stepvan Cab Heater BX2200
   / Sims Cab with Stepvan Cab Heater BX2200
Sim's cab 9
   / Sims Cab with Stepvan Cab Heater BX2200 #23
The picture that I would like to see was the rear of the tractor. Does the rear have glass or plastic. How hard would it be to remove the rear panel to use this cab on a BX22???? thanks for the pictures.... Junk....
   / Sims Cab with Stepvan Cab Heater BX2200 #24
I like your cab. /forums/images/graemlins/smile.gif
Any pictures of how the lid was put on weight box?
Does it have hinges?
   / Sims Cab with Stepvan Cab Heater BX2200 #25
Junkma
From the Sims web site
web page
Standard Features
Heavy Duty Steel Top With Accoustical Headliner
Right Hand Door, Snapped Vinyl Panel With Clear Poly Window.
Steel Framed Windshield With Tinted Safety Glass
Rear Window, Tinted Safety Glass, Fixed
Rear Side Windows, Tinted Safety Glass.
Left Hand Door, Steel Framed With Vinyl And Clear Poly Panel, Hinged With Latching Handle.
Single Speed Electric Wiper Assembly
For Larry
Question I have is did you buy direct from Sims? or use a dealer? How long did it take for you to install the cab?
Thanks.
NY Yankee Fan I bought though my Kubota dealer and it took the best part of a day to assemble and put on. The directions that came with it are a lot to be desired
Junkman here is a pic of the rear panel of the Sim's cab. It has 6 bolts holding it on and is removed from the inside and it is a safety glass window, hope this helps
Dean here is 4 pic's of the 60" BX2763 blade and the BX2751 quick hitch
NEW Fork Extensions (A53002)
NEW Fork...
John Deere M Tractor (AS IS) (A50774)
John Deere M...
2016 John Deere Gator 825i 4x4 Utility Cart (A50322)
2016 John Deere...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
2014 Dodge Charger Sedan (A50324)
2014 Dodge Charger...
Adams 5 ton Fertilizer Buggy / Wagon (A52748)
Adams 5 ton...
