Sizing a Backhoe Thumb Cylinder
   / Sizing a Backhoe Thumb Cylinder
dfkrug said:
OK, I am with you here. Regardless of whether you close the bkt against the object touching the thumb or close the thumb against the object touching the bkt, the max force will be what the bkt circuit can deliver since it is greater than the thumb's force. The actual force will be
that delivered from the last circuit operated; 4000 if from the thumb, 5700 if from the bkt. Yes, the max resultant force on the cyl should be kept to 3000 if that is the spec for the cyl you buy. If you are getting that amount of force from the bkt, you should just do what you planned, go for a bigger ID (2.75). I am with you.
Okay! :) Glad we are back on the same page. :cool:
Now... where the heck do I find this silly cylinder??? :confused:
Dougster
MtnViewRanch said:
TIME. I suppose that I could have just used my 16hp Sears garden tractor.:D Heck, I have a MMM, a 36" disk, 36" rear blade, even a 36" rollover Gannon for it.:) I guess that I could get stuff done on my 80 acres and my brothers 40 next to mine in no time at all. Shoot, might only take my lifetime.:rolleyes: Just think of all that seat time.I actually wanted a bigger New Holland,(100hp) but could not afford it.:(
My point exactly my megabucks rich, left coast dwelling, 7520 driving, land baron friend! :D Just because I am dirt poor and living in Taxachusetts doesn't mean I want to make my 509's new fixed thumb into a useless toy! ;) The day you buy a 2015 is the day you can tell me to back off on the performance capabilities of my beloved red (even though not a 7520) machine! :D
New Holland 100 HP... heh? You must really LOVE the color blue!!! :D
Dougster
   / Sizing a Backhoe Thumb Cylinder #33
Dougster
Hey, what year is that Chevy truck that you drive, me I'm running around in a 1988 F250 with 276,000 miles and the ac quit working and it's in the 90's out here.:(
Anyway, I still don't understand why you need that much pressure on the thumb.:eek: Are you trying to crush stuff?:confused: I thought that a thumb was to hold stuff to be able to get it out of the way.(which I could use digging out the 100's of scrub oaks that need to be removed) What am I missing out on? Could I be in need of one of these for my 580? It's already plumbed for aux hydraulics.:)
MtnViewRanch said:
Hey, what year is that Chevy truck that you drive, me I'm running around in a 1988 F250 with 276,000 miles and the ac quit working and it's in the 90's out here.:( Anyway, I still don't understand why you need that much pressure on the thumb.:eek: Are you trying to crush stuff?:confused: I thought that a thumb was to hold stuff to be able to get it out of the way.(which I could use digging out the 100's of scrub oaks that need to be removed) What am I missing out on? Could I be in need of one of these for my 580? It's already plumbed for aux hydraulics.:)
You know that I am so close to broke I can taste it. :( One can of soup a day, one tea bag and one or two stale slices of bread. You could never live like this... but anytime you feel like exchanging equipment, bank accounts and real estate... I am soooooooooo ready! :)
All I can say is THUMBS ROCK!!! :D And hydraulic thumbs are the cream of the crop... provided, of course, you aren't giving up too much performance. And performance for a thumb is lifting and gripping power!!!
Of course you should have a thumb on your 580. I'm surprised that you don't have one already. Sell that new Hummer and get thee a thumb!!! :cool:
Dougster
   / Sizing a Backhoe Thumb Cylinder #35
Dougster
A Hummer, no Hummer here, I wish that I could afford one, not that I want one, just wish that I could afford one.:cool:
Back to the thumb, I guess that I'm worn out today or something,:confused: what good would it do if you had a thumb that put a kabillion :eek: lbs of pressure on that tree trunk that is stuck in the ground. The hoe is not going to be able to lift it. It may not let go, but it still won't lift it. If you want to be able to hold something with 5000lbs pressure that requires 5000lbs of pressure to hold it, will your hoe still move it, or is that something now to heavy for you to be able to move? Does any of this make any sense?
Ahhh... no. :( Not to me anyway. The thumb is there to grip things... for whatever reason you want... it grips things. Sometimes it crushes and splits things apart, but mostly it grips. And the harder it can grip those funky things you want to grip, the better. Whether pulling trees or moving rocks or picking up construction debris or just scaring neighborhood kids away... more gripping power is simply better. It does not increase or decrease what you can lift. It just grips. Why would I want less gripping force than I've already got with the fixed arrangement (other than for the added convenience)? Makes no sense.
That's the best I can explain it at this time of night. :eek:
Dougster
   / Sizing a Backhoe Thumb Cylinder #37
Dougster,
If I have my thumb extended and close my bucket I can push the thumb back, likewise if I extend the thumb into the bucket I can push the bucket back........and if I want to try to push the noodle with both simutaneously these just turn that mean ol noodle into spaghetti :D without either side gaining ground. I surmise that's what you're trying to emulate.
MadDogDriver said:
Dougster, If I have my thumb extended and close my bucket I can push the thumb back, likewise if I extend the thumb into the bucket I can push the bucket back........and if I want to try to push the noodle with both simutaneously these just turn that mean ol noodle into spaghetti :D without either side gaining ground. I surmise that's what you're trying to emulate.
Good photo... very similar in geometry to the Bradco! :)
I'm just trying to convert my fixed thumb to a hydraulic so that a) It will rattle less, b) No getting off the seat to set it up, and c) because hydraulic thumbs are the cat's meow! :cool:
I just don't want to lose excessive gripping force while doing so. Simple as that. :)
Dougster
   / Sizing a Backhoe Thumb Cylinder #39
Dougster
I understand that you want to be able to hold things tight, I guess that what I don't understand is why hold something with 5000lbs of force that only needs to be held with 2000lbs of force. Your hoe isn't going to move a 2000lb object is it? So what is the purpose of getting that 5000lb clamping force? I guess my point might be, why not use the 2 1/2" cylinder with the 4000lb gripping power and get the convenience of the hydraulic thumb. That in itself most likely exceeds the capacity of your hoe.
I'm tired and may not be thinking clearly, so I will go away and be quite now.
   / Sizing a Backhoe Thumb Cylinder #40
MadDogDriver said:
Dougster,
Based on your description, Woods must have designed for similar
net forces applied by the thumb and bkt, then added a relief
valve to each circuit so they would retract under opposing pressure.
Otherwise opposing pressure would have exceeded the pressure
limits of the cylinders. I find it a bit surprising that the thumb can
push the bkt back. I wonder what pressures they are seeing.....
They also may have INTENDED the user to be able to push either
back by the other so he could position his load. The problem I see
here is only if a relief in the bkt circuit is set lower than max press,
which limits your digging capability. A tradeoff.
Based on what I think Dougster is trying to do, I think he should
get a 2.75" cyl so he can maximize forces without needing a relief
valve.
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A55302)
2019 BOBCAT T630...
2018 John Deere 1653 (A55302)
2018 John Deere...
(INOP) VOLVO L70H WHEEL LOADER (A51243)
(INOP) VOLVO L70H...
2015 Nissan Versa Hatchback Sedan (A55758)
2015 Nissan Versa...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
