Small bridge
/ Small bridge #11
The problem with RR ties in your method is you will have loading on the two you are driving on. The strenght of a beam is HHHxW/l. That is the height cubed x width in porportion to it's length. So tall beams are good. RR ties are nearly square, 9" x 7" by 9'7" long. Look at a floor joist, note H is quite large!
The size of the beam is reduced as the length is reduced. Reduce the span as much as you can. The creek bed may be large, but what is the water flow?
/ Small bridge #12
BrainZ, One Telephone pole cut up into lengths would work IMO you would need four lengths for the beams then your planking on top, Quick and dirty it would last a good while... But not like two beams and a concrete footer ;)
RR ties isn't as good an option IMO...weight wise , although it is only 5' span
JusT MY 2 cents
2014 CATERPILLAR 303.5ECR EXCAVATOR (A62129)
2014 CATERPILLAR...
2024 DEVELON DL250-7 WHEEL LOADER (A59823)
2024 DEVELON...
2007 FREIGHTLINER M2 106 4X2 26FT BOX TRUCK (A59906)
2007 FREIGHTLINER...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2000 TEREX 60TON T560 REAR WHEEL DRIVE CRANE TRUCK (A59906)
2000 TEREX 60TON...
