Snapped excavator bucket tooth shank
   / Snapped excavator bucket tooth shank #22
You got plenty of advice how to go about getting the tooth shank off. Torching would be the messiest but can be done. Myself, I would air-arc. It takes a heavy duty cycle welder though. Another option would be to have a welding shop do it for you if you do not have equipment on hand.
Now once off, use 8018 welding rod and preheat the area to several hundred degrees before proceeding to weld.
   / Snapped excavator bucket tooth shank #23
At the welding shop I work at we regularly weld shanks (we call them adaptors) on excavator buckets. Everything from the little backhoe buckets to large 4 yard severe service buckets. The cutting edge and adaptors are preheated to 300f and make sure the inter pass temperature does not exceed 500f. I agree the esco adaptors do seem to be the most reliable but we dont generally have too many problems with any brand we use.
I also priced it with a local welder and he quoted $250 to $300 coming to my home. Looks like I will be doing it myself. Probably will be a little messy since all I have is an oxygen/acetylene torch and 7018 rod.
   / Snapped excavator bucket tooth shank #26
You can do a pretty surgical weld removal with oxy-fuel. Just run a small tip with low pressures and shave the welds down a little at a time. If you try to take the whole weld with 1 pass it will for sure be messy. Good luck !
   / Snapped excavator bucket tooth shank #27
For “shaving” cuts I like to pivot the torch on the nut that secures the cutting tip resting on the work. In this case the edge of the bucket.
   / Snapped excavator bucket tooth shank #28
Pick up a gouging tip for your oxy acetylene torch makes it a little easier to control
   / Snapped excavator bucket tooth shank #29
Another good option.
I’m usually too lazy to swap out the tip though ...
   / Snapped excavator bucket tooth shank #30
how did you make out with this project liberty2701? just curious, at work when we have a warranty claim or some sort or rework needs to be done it usually ends up being my job to cut it apart and rebuild it. Not complaining i actually like doing it.
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1EF7EKF89312 (A57453)
2014 Ford F-150...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A55315)
2021 Unverferth...
2011 Ford Explorer Limited AWD SUV (A56859)
2011 Ford Explorer...
2015 AMERITRAIL MANIFOLD TRAILER (A55745)
2015 AMERITRAIL...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2015 UTILITY VS2RA 53FT REEFER TRAILER (A57880)
2015 UTILITY VS2RA...
