Snow Attachments Snowblowers vs PTO HP
   / Snowblowers vs PTO HP #51
From responses so far, it seems the old rule of thumb, 5 hp for each foot of snowblower width is often broken with success - guess that's why it's only a rule of thumb.
I'm running a B2782 63" front mount blower on my 27 PTO hp B3350. No issues for want of power.
   / Snowblowers vs PTO HP #52
It's all about ground speed. I run a 6' 3pt blower on my L4200 (37 PTO HP). I was running it on my driveway - WFO in 4th gear up a 10-15% grade while blowing 20+ inches of snow, which was WAY too fast. My tractor or blower never missed a beat, but after the 500' climb at the top of my drive, I looked down and sparks were shooting out of my engine compartment - not like a few sparks, but a shower - like what you see flying off of a 9" grinder. It stopped after a minute or two and all was fine - I figured that I worked the engine hard enough to ignite carbon deposits in the head and exhaust. Scared the crap out of me, but was probably good for the engine.
   / Snowblowers vs PTO HP #54
85hp on 84inch really wouldn't want any less
I'm with you. 80" Lucknow with 4" side wings on an M9 (87 pto Kubby). I could use about 15 more in deep drifts over 4 feet. Blows a bit of smoke and the hairdryer is screaming but thats what it's for.....
I believe blowing works the tractor harder than any hay making does.
Sure sucks down diesel.....
   / Snowblowers vs PTO HP #55
I run a 60" on my B7800 (30 HP). Never have had a problem. Ground speed is important - essentially the trick is to keep feeding the blower at the proper rate to keep the snow flying! I have 1.5 miles of dirt road and I usually plow the storm with my F-350 then when the skies clear I blow the banks back to make room for the next storm and to keep the snow off the road in preparation for spring melt to minimize mud season.
   / Snowblowers vs PTO HP #56
A plow pushes snow around, quick if the snow's not deep, but certainly not exciting. And if you've a long driveway and no place to stack it so it's not in the way, it can get exasperating and starts to feel like work.
A blower, on the other hand, especially one with a nice warm cab, most always is fun. For a blower fairly launches snow, scattering it far . . . it imbues the operator with a sense of enormous power and control . . . here, Mother Nature, take THAT!!
   / Snowblowers vs PTO HP #57
I run a 72" Puma blower with my CK35 with no problems at all. As a lot of people have mentioned already, speed is key. Bought this blower on the side of the road for $1100 with hydraulic chute and deflector. Couldn't pass it up. :D
   / Snowblowers vs PTO HP #58
What kind of speed are you seeing? 20" of snow is not going let a 37 hp tractor (pto) go very fast, fast being a relative term. I run a NH TL100A Deluxe, with 93 pto hp, with a Normand 92-280 Inverted blower. Max speed i am seeing, in 4" is a bit over 7mph, with out spilling any snow. 20" and I'm down to about 3mph. But I'm throwing so much snow, with such velocity, that i need to be careful where I'm throwing it. I usually see between 475 and 570 rpm on the pto.
   / Snowblowers vs PTO HP #59
I ran a Woodmaxx 60 inch, 695 pound snow blower off of a JD 855, 24 HP with 19 @ the PTO worked fine just a little slow. This year I up graded to a 2032R, 32 HP with 24 @ the PTO. Hate snow but looking forward to one good storm.
   / Snowblowers vs PTO HP #60
Why do people want to put the biggest blower they possibly can on their tractor? I couldn't imagine having the blower stick out a foot on each side. Yes, with hst you can always slow down but on the same page you can always speed up with a smaller blower. 6' of heavy or drifted snow is a lot on the first pass when you have to take a full bite when pushing the HP limits
Entyre Chip Spreader (A57453)
Entyre Chip...
2018 Ariens Ikon X52 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
Echo 602VL Chainsaw (A57454)
Echo 602VL...
2002 Ford F-350XL Super Duty (A57148)
2002 Ford F-350XL...
Niagara No. 46 Shear (A59213)
Niagara No. 46...
UNUSED TRACK SKID STEER AR500 3/8" STEEL SHOOTING (A58376)
UNUSED TRACK SKID...
