Snow Attachments Snowblowers vs PTO HP
   / Snowblowers vs PTO HP #61
Why do people want to put the biggest blower they possibly can on their tractor? I couldn't imagine having the blower stick out a foot on each side. Yes, with hst you can always slow down but on the same page you can always speed up with a smaller blower. 6' of heavy or drifted snow is a lot on the first pass when you have to take a full bite when pushing the HP limits
   / Snowblowers vs PTO HP #63
I agree. I have a Kubota 51" blower on my BX25, and is plenty big enough. Nor do I ever run out of PTO power.
How wide is your tractor footprint? Obviously that's a big factor in the size of the snowblower. In my case, I'm going to end up going with a Farm King 60". The next size down is a 50" which will be too small. If they made a 54" I'd be all over it.
   / Snowblowers vs PTO HP #65
What kind of speed are you seeing? 20" of snow is not going let a 37 hp tractor (pto) go very fast, fast being a relative term. I run a NH TL100A Deluxe, with 93 pto hp, with a Normand 92-280 Inverted blower. Max speed i am seeing, in 4" is a bit over 7mph, with out spilling any snow. 20" and I'm down to about 3mph. But I'm throwing so much snow, with such velocity, that i need to be careful where I'm throwing it. I usually see between 475 and 570 rpm on the pto.
4th gear is roughly 3MPH. Doesn't seem like much, but it is :). I usually run 2nd when its deep, or 3rd when it's not. 4th in the deep was pushing the HP limit of my tractor, for sure - hence the shower of sparks that it was belching out.
   / Snowblowers vs PTO HP #66
Most drives are 12', so with a 6' blower, you just have to go up and back and you're done. With a 5' blower, you have to make 3 passes, then drive all the way back, so it takes TWICE as long.
   / Snowblowers vs PTO HP #67
I ran the buhler 60 (same thing as the farm king) on my JD755(A little less PTO HP than yours) for years without any problems. Yes you can bog it down a bit if you move too fast into a deep drift but for the most part it worked well.
   / Snowblowers vs PTO HP #68
I'm with you. I went from 60" to 50" now to 47" front mount. Generally speaking most people likely spend 1/10 snow blowing compared to mowing. I went with widest mower. The blower I went with what functioned the best with my tractor.
   / Snowblowers vs PTO HP #69
I run a 72" Puma blower with my CK35 with no problems at all. As a lot of people have mentioned already, speed is key. Bought this blower on the side of the road for $1100 with hydraulic chute and deflector. Couldn't pass it up. :D
How hot was it? You stole that!
   / Snowblowers vs PTO HP #70
I won't argue on the widths of drives as I have no reference but my own that I clear 16-18' wide.
I will disagree on the time though. When you have to drive considerably slower because you are underpowered it offsets things. You need 20% more power to run a 6' over a 5'
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56436)
LMC 2-Row Planter...
2007 STERLING TRUCK L9500 CHEMICAL TRANSPORT TRUCK (A58214)
2007 STERLING...
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2021 RAYCO C120RA FORESTRY MULCHER (A52709)
2021 RAYCO C120RA...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
